Old 09-19-2020, 06:39 PM   #1
Frunk not opening all the time
I just recently acquired a 2002 boxster S and I absolutely love the car but one issue so far with it is the frunk will not open half the time. I’ve noticed when I press the frunk button on the key fob if it doesn’t work, it will instead unlock the doors. I have also tried opening it from the interior and that will not work either. Keep in mind this is the updated model with the electronic frunk/trunk buttons by the drivers seat.
I’ve searched this all over online and haven’t found any definitive answer to my problem. Anyone else have this issue? Does it need a new frunk motor? What else?
Ohtwo986S is offline   Reply With Quote
Old 09-19-2020, 11:52 PM   #2
I had same issue on my 2001 Boxster with electronic frunk opening system.
Repair was to replace the frunk opening actuator - new unit from Porsche at the price of about 70€. I don't recommend to buy a used part for this.
The electronic motor on the actuator heats up due to old age (dirt, tired electronics, etc) and does not work when warm.
This is easy change, but requires frunk to be open for the job. The swap from old to new actuator took me about 20 minutes.
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
Old 09-20-2020, 01:08 AM   #3
Multi-Boxer Driver
Deserion's Avatar
Also second replacing the actuator. Had the same issue a few years ago.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 09-20-2020, 10:09 AM   #4
2003 S, Arctic Silver, M6
paulofto's Avatar
This issue has started with mine as well. I could hear the actuator engaging but the hood wouldn’t pop up to get my hand in to release the secondary catch. I finally got my fingers under while hitting the release button and finally opened. Some lubrications of all the parts seems to have fixed things for now but I’m going to order the parts and get it fixed.
Old 09-20-2020, 08:13 PM   #5
Thanks for the help. I’ll spray some wd40 on the mechanism for now and order the part after. I couldn’t find it on pelican parts though.
Also... why does this forum show threads in backwards chronological order?
Old 09-20-2020, 08:55 PM   #6
Multi-Boxer Driver
Deserion's Avatar
User CP>Edit Options>Thread Display Options
Actuator is #996-511-127-00
-Chris
Old 09-21-2020, 04:48 PM   #7
I second the actuator replacement. When you do get it open, relocate the emergency trunk opener cable from the passenger side headlight To the tow hook access panel on the front bumper. That way it can be opened manually. There are YouTube videos on the procedure.
Blackcloud is offline   Reply With Quote
Old 09-28-2020, 06:53 PM   #8
I have the same issue with my 2002 that I just got. I bought a new actuator and it was not the issue. Turns out the relay that was mounted in the trunk under the tub was not always closing the connection. If I tapped on it the trunk would then open 2 or 3 times before stopping again.
subieworx is offline   Reply With Quote
Old 04-04-2021, 01:41 PM   #9
Sounds like an actuator replacement may be what you need, @Ohwo986s
Here's a video:
https://www.youtube.com/watch?v=59K7yBvQ06I
Drywall is offline   Reply With Quote
