Old 09-20-2020, 08:00 PM   #1
245/40/18 Rubbing fender wall check my math
02, 986 non-s, bone stock.
Bought a set of 18x8.5 on 245/40/18 and 18x9.5 on 275/40/18. The 245's rub just a bit at full stop on the inner fender wall. Need about another .25" of clearance. (had a hinting suspension this would be the case).
THE KICKER IS:
The current tires are just about toast, so new ones will be bought (known beforehand and price accounted for). A search on the forum showed that members claimed success on 245/18(assuming different suspension??), 235/18, and 225/18.
225's would return the wheel to just about the 25.1" diameter the oem 17's have (good!) BUT are the lowest size for the 18x8.5 and bring the side walls to 3.5"
235's are a 'recommended' size for the 18x8.5 increase the side wall to 3.7" but also the diameter to 25.4". Just .3" less than 245's (which rub apparently).
The question! I think a can get away with 235/40/18 but am I flying too close to the sun? What say you?
Here is a picture in bad lighting and a frustrated hand.
DTW986 is offline   Reply With Quote
Old 09-20-2020, 08:09 PM   #2
To give any educated guidance - what is the wheel offset?
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 09-20-2020, 08:18 PM   #3
PO didn't know. I measured and came up with roughly 50 ET
Old 09-21-2020, 07:01 AM   #4
Racer Boy
Racer Boy's Avatar
The offset should be stamped on the wheel.
Old 09-21-2020, 07:43 AM   #5
2013 cayman rim offset
These are the offsets from my factory cayman rims. They are stamped on back of rim
Kdnatchez is offline   Reply With Quote
Old 09-21-2020, 08:17 AM   #6
M 40 = ET?
I saw this before but that didn't seem right. These are wheel dynamics
Old 09-21-2020, 08:18 AM   #7
The only other markings
Old 09-21-2020, 01:57 PM   #8
WillH's Avatar
I am running 235s 49 offset with 12mm spacers here and they rub the front of the wheel well when the wheels are cranked over. I remember someone saying that there is a way to adjust the wheel well liner but I haven’t looked into it yet as it’s not bothering me enough to. Leaving it for when it’s put up for winter.
Also thought 245s rub the strut spring perch.
