Old 09-20-2020, 08:00 PM   #1
DTW986
245/40/18 Rubbing fender wall check my math
02, 986 non-s, bone stock.
Bought a set of 18x8.5 on 245/40/18 and 18x9.5 on 275/40/18. The 245's rub just a bit at full stop on the inner fender wall. Need about another .25" of clearance. (had a hinting suspension this would be the case).
THE KICKER IS:
The current tires are just about toast, so new ones will be bought (known beforehand and price accounted for). A search on the forum showed that members claimed success on 245/18(assuming different suspension??), 235/18, and 225/18.
225's would return the wheel to just about the 25.1" diameter the oem 17's have (good!) BUT are the lowest size for the 18x8.5 and bring the side walls to 3.5"
235's are a 'recommended' size for the 18x8.5 increase the side wall to 3.7" but also the diameter to 25.4". Just .3" less than 245's (which rub apparently).
The question! I think a can get away with 235/40/18 but am I flying too close to the sun? What say you?
Here is a picture in bad lighting and a frustrated hand.
DTW986 is offline   Reply With Quote
