Old 09-06-2020, 01:55 PM   #1
Shacky
Boxster front pass drain tube - I screwed up!!!
While trying to unclog my front passenger drain tube. I decided to remove positive battery cable. Did battery side first then firewall. I used my fingers to remove nut once it was loose in order to NOT let id drop into the drain hole.
Well that's exactly what I did. It's down in there good. Tried a plumbers grabber with no luck. I believe this is the most difficult tube to get at.
So now I have a nut and a clog to deal with.
Any advice? Please no wise cracks I'm not in the mood
shacky is offline   Reply With Quote
Old 09-06-2020, 03:40 PM   #2
have you tried an extendable magnet?
You may be able to get down in there with one.
Otherwise how difficult is it to remove and replace the drain tube?
Old 09-06-2020, 03:50 PM   #3
Shacky
Excellent idea. Magnet I have is too wide. Will look for narrow one tomorrow 😉
Old 09-06-2020, 05:07 PM   #4
an auto parts store should have the extendable type.
Napa for sure I would think.
let us know how it goes.
Old 09-06-2020, 05:55 PM   #5
piper6909's Avatar
Excellent idea. Magnet I have is too wide. Will look for narrow one tomorrow ��
Those extendable magnets don't flex. I don't know if those drain tubes have bends or not, but sticking a stiff object in there may cause you even more problems. I've seen one thread where a guy pushed a drain tube in and it got detached. I don't know what he had to do to retrieve it.
If I were you, I'd find a small magnet and tape it to a flexible cable like a bicycle brake cable or something. Lowe's sells this thing called a "drain Weasel" it's a long flexible plastic thing that's used to snake out sink drains. See if you can tape a small magnet to something like that.
Good luck.
2010 Subaru Forester
Old 09-06-2020, 06:16 PM   #6
Shacky
This looks like it would fit the bill
https://shop.advanceautoparts.com/p/performance-tool-magnetic-retriever-w25934/11931886-P
Old 09-07-2020, 04:04 AM   #7
Newbie
This might be helpful.
https://sites.google.com/site/mikefocke2/drainsdiagram
Sent from my SM-G965U using Tapatalk
1998 Porsche Boxster Base - 2005 Volvo S60R AWD - 2003 Subaru Wrx Wagon - 2003 Jeep Wrangler Rubicon - 1992 Subaru Loyale Wagon w/4in Lift - 2004 Dodge Ram 2500
GLImages is offline   Reply With Quote
Old 09-07-2020, 11:48 AM   #8
Shacky
Picked up this small magnetic retriever. Worked like a charm! Now I’m try to figure out if I pushed tune down yesterday 🙄
Can’t upload iPhone pics
Old 09-07-2020, 01:04 PM   #9
good to hear it worked out
Old 09-07-2020, 01:12 PM   #10
Shacky
So now that nut is out of the way I want to make sure I'm not doing any more damage before trying to clear blockage. Is this ridged area the actual tube or did I push the tube down?
Old 09-07-2020, 01:17 PM   #11
Shacky
Lets try this again
Old 09-07-2020, 05:59 PM   #12
Lets try this again
Sorry I can't help you with your latest question.
But as to cleaning them out I would use a vacuum or forced air.
Forced air in reverse direction of water flow (if you can get to the outlet) should dislodge any blockage, I would think.
Old 09-08-2020, 03:23 AM   #13
piper6909's Avatar
Lets try this again
That looks like the drain tube, and it looks like it is properly seated.
Old 09-08-2020, 05:57 AM   #14
Shacky
Appreciate it 😉
Old 09-09-2020, 10:45 AM   #15
Shacky
Ordered tuba cleaning wire. After getting one of the fuzzy end tips stuck in the tube I was able to get the bare wire all the way through from bottom up. This opened it up a bit but it’s still blocked. And now with a fuzzy in there.
Pulled wire back through and nothing came out. Tried pressure washer from top - helped a little and back up through top came a piece of rubber wire protector that was obviously stuck in there.
Can’t get the wire all the way through again. If/when I can I’m thinking of tightly connecting something that will pull through whatever is in there.
For now taking break so I don’t get frustrated and break something.
Old 09-09-2020, 11:59 AM   #16
piper6909's Avatar
Do you have a shop vac with a crevice tool? Try sucking it up from the top. Cup around the crevice tool with your hand or make something out of duct tape so no air gets sucked in from the sides.
