Old 09-06-2020, 04:40 PM   #2
blue62
Originally Posted by shacky View Post
While trying to unclog my front passenger drain tube. I decided to remove positive battery cable. Did battery side first then firewall. I used my fingers to remove nut once it was loose in order to NOT let id drop into the drain hole.
Well that's exactly what I did. It's down in there good. Tried a plumbers grabber with no luck. I believe this is the most difficult tube to get at.
So now I have a nut and a clog to deal with.
Any advice? Please no wise cracks I'm not in the mood
have you tried an extendable magnet?
You may be able to get down in there with one.
Otherwise how difficult is it to remove and replace the drain tube?
