Old 08-01-2020, 01:02 PM   #1
Makes sense. But I thought the LN requires a lower torque than the OE Plug. If both the original and LN plugs are aluminum, why do the LN plugs spec such a lower torque and why are they stripping?
From what we have seen, operator failure.
Old 08-02-2020, 05:25 AM   #2
piper6909's Avatar
There has to be more to it. Maybe the LN plug is more finicky and less forgiving of the aforementioned operator error than the OE plug?
From what I've read on here, it seems that there's a very narrow window between not enough torque that the aluminum washer won't seal and too much torque that will strip the inside metal from the outer aluminum threads. That's just my observation.
2010 Subaru Forester
Old 08-02-2020, 06:41 AM   #3
"50 Years of 550 Spyder"
10/10ths's Avatar
That’s why....
....When you invest in the LN magnetic drain plug, it comes with instructions. And the instructions are on their web site.
Read the instructions when you buy a new product. Read the owner’s manual in your car. Engineers spent a lot of time and money and blood, sweat, and tears to engineer these things and then write up detailed instructions for their customers to make sure everything works as engineered.
But people are lazy and don’t want to take five minutes to READ.
People will drop $100,000 on a car, and then not take five minutes to read how to care for that car.
Forgive my rant, but I work in the automotive industry, my specialty is technical instruction.
I always ask folks, “If you bought a private jet, would you make sure you knew how to change the oil properly before you flew across the ocean?”
If you can’t take five minutes to read the owner’s manual, and make sure your car doesn’t dump out all its oil on a drive across Montana, then you shouldn’t buy the car.
Harsh? No. Reality? Hell yes.
RTFM.
I’m done. Thanks for your time. Return to your normal programming.
Old 08-02-2020, 12:11 PM   #4
piper6909's Avatar
RTFM.
Here's the problem: The owner's manual is useless to those who have an LN plug, because LN specs much lower torques.
So if someone buys a used Box that came with the LN plug, then changes the oil and torques, as you said, to spec in the owner's manual, they will most likely damage the plug. Likewise, if they took it to an indy or quick oil change place that may not necessarily know that LN specs a different torque. Even if they use a torque wrench, they probably would torque it to the spec that their computer tells them, which is derived from the manufacturer's specs, not aftermarket products.
So instead of just blaming the user, you would think LN would have just developed a plug that used similar torque specs as the OE plug.
Old 08-02-2020, 03:00 PM   #5
A Porsche Guy
1PorscheBoxster986's Avatar
For those who are interested in purchasing one, LN is selling the latest revision which has the torque spec and their logo laser etch(not grooved) into their magnetic oil drain plug. It should help solve the problem for you; until the etching eventually wears off . The same one NJbray used.
1PorscheBoxster986 is offline   Reply With Quote
Old 08-02-2020, 04:47 PM   #6
piper6909's Avatar
Or you can buy the one that uses the same torque as the OE plug and eliminate any chance of someone getting it wrong.
Old 08-02-2020, 05:33 PM   #7
A Porsche Guy
I know you're playing devil's advocate here, good job, but in the real world it's 19 ft-lbs to torque the magnetic plugs from LN .
I have never used my magnetic drain plug and the OEM one I use requires 37 ft-lbs still. I've been fortunate to use Frodo's free new crush washers I offered for all my oil changes. I made sure that guy who guarantees the warranty to the work torques down correctly and knows the bolt/screw to use because I hate to go back into a job after I patted myself well done .
Old 08-02-2020, 09:47 AM   #8
I would not bet on that. We have installed a lot of these plugs, torqued them to LN’s specs, and never had a problem with them. That said, we have also seen quite a few that we did not install that had become “problems”. The common denominator between the two seemed to us to be how they were installed. After multiple oil changes (which we did), the plugs we installed looked brand new; the problem plugs brought to us for the most part looked like they had been through a war with Allan flats rounded off, parts of the plug head chewed up, and some in so tight that they must have been installed with a breaker bar.
Old 08-02-2020, 10:51 AM   #9
Geeeeeez, I wish I’d never stumbled into this thread.
After 11 years of virtually trouble-free oil changing experiences with my magnetic plug (sans torque wrench!) I’m just sure it’s all gonna go to hell in a handbasket from here on out.
Old 08-02-2020, 06:47 PM   #10
Qingdao's Avatar
You and me both...
All this for a magnetic drain plug on an aluminum engine block. Most people on here when they get all concerned about metal shavings in their filters the metal shavings are bronze/brass in nature (guide failure??? IDK I've never been inside a flat 6 engine).
I mean you pull your drain plug out and its covered with iron shavings; you've already had problems. Like doing 5 laps WOT and then seeing your oil pressure is 0.
'98 PP13B powered "RX986"
Old 10-18-2020, 08:37 PM   #11
jaykay's Avatar
Does LN supply the Porsche crush washer with their plug? If not I have I have been a very lucky dude..
986 00S
Old 10-19-2020, 06:52 AM   #12
I have no idea whose crush washer they use, but I have used the factory crush washers as replacements on the LN plug for years without any issues.
Old 10-19-2020, 07:04 AM   #13
+1. OEM crush washers from Amazon and proper torque, which I think is stamped on the LN plug.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 10-19-2020, 11:28 AM   #14
jaykay's Avatar
Thanks JFP....you got it even if I typed that the wrong way...
986 00S
