Old 06-29-2020, 04:15 PM   #1
Doing oil change, what size is the crush washer
It seems Walmart is the place to buy oil, $22.88 for 5qt jug of Mobil 1 full synthetic and $7 for K&N filter. They don't list crush washer by name, only by size. What is the size needed for the drain plug?
Also, I'm in the burning AZ heat so going to use 0-40, and that's what's the prior owners used from looking at the Porsche dealer records.
Also, they have a really cool 15qt drain container for $10 that I saw on Amazon for $20
Jasper7821 is offline   Reply With Quote
Old 06-29-2020, 05:00 PM   #2
Phat Hippy's Avatar
Buy the crush washers from the forum host they are inexpensive. Depending on the age and mileage of your car... You may want to consider using a 5-40 spec oil due to the heat in AZ. I have been using probably some of the most expensive oil I have ever put in any vehicle I've ever owned. Joe Gibbs DT-40. Gets hot here in CT too. I think many will agree changing the oil is the best thing you can do for these cars. Enjoy.
Phat Hippy is offline   Reply With Quote
Old 06-29-2020, 06:55 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
Originally Posted by Phat Hippy View Post
Buy the crush washers from the forum host they are inexpensive. I think many will agree changing the oil is the best thing you can do for these cars. Enjoy.
+1 please show Pelican Parts some love when you need parts.
Old 06-30-2020, 10:18 AM   #4
Thank you, I was going to use 5-40 since that's what the dealer has been using.
The car is 2001 with 104k miles.
Old 06-30-2020, 10:19 AM   #5
For sure, buying the window regulator from them. And also some rear suspension parts when I figure out when the little clunk is in the right rear.
Old 06-30-2020, 02:59 PM   #6
Multi-Boxer Driver
Deserion's Avatar
It’s an 18x24 aluminum washer. Part #900-123-106-30 for reference.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 06-30-2020, 08:58 PM   #7
Thank you very much
Old 07-01-2020, 05:51 AM   #8
1998 Boxster Silver/Red
That only took 27 hours.
1998 Porsche Boxster
