Old 06-21-2020, 07:05 AM   #1
Gjohn3707's Avatar
Painted rotors
I noticed corrosion on my rotors from condensation during winter storage. It was getting worse every year, so I bought some high temperature caliper paint. I cleaned the rust off and gave them a couple light coats being careful to avoid the braking surfaces. Hopefully this will not burn off and prevent further corrosion.
Took time to clean and wax the wheels too.
2001 Seal Grey Boxster Base
Gjohn3707 is offline   Reply With Quote
Old 06-21-2020, 05:15 PM   #2
Will there be cake?
tonythetiger's Avatar
That should be a standard practice when performing brake job, and brake quiet, anti seize etc.
Old 06-21-2020, 06:26 PM   #3
TRP
Looks great!
TRP is offline   Reply With Quote
Old 06-23-2020, 03:10 PM   #4
Gjohn3707's Avatar
finished job
Old 06-23-2020, 04:06 PM   #5
jaykay's Avatar
Sharp man...did you bake between coats ?
986 00S
Old 06-24-2020, 06:03 AM   #6
Gjohn3707's Avatar
Jaykay No I didn't. I tested them with a few hard stops and this picture was taken afterwards.
Old 06-24-2020, 06:43 AM   #7
Dave80GTSi's Avatar
If you paint the hubs the same shade of red as the calipers (as you can see that I have done), the caliper and the hub seem to compliment each other nicely.
And while you are at it, inexpensive lug bolt cover caps, easily found on such as eBay, eliminates the sometimes scuzzy OEM lug bolt appearance.
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
Dave80GTSi is online now   Reply With Quote
Old 06-24-2020, 07:12 AM   #8
kk2002s's Avatar
I did rotor caps with high temp spray paint and they lasted years. I used same paint on lugs as well. Each time I took wheels off for any multi-day work, I hit them with a coat of paint to keep them looking good.
Seal Grey
Old 06-25-2020, 03:51 AM   #9
flouese's Avatar
Can you use POR 15 to do this project?
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 06-26-2020, 05:37 AM   #10
Gjohn3707's Avatar
Flouese POR 15 should work but get the high temp for caliper. I think this area of the rotor could get hot.
