Coolant flush and what else.....
I'm prepping to do the coolant flush and fill. Got to thinking and I am wondering if there is anything else that I should replace in association as long as I'm changing the fluid anyway.
Any suggestions or recommendations? 2001 Boxster, Tiptronic, 84,000 miles |
Water pump and thermostat.
Sent from my Pixel 3 using Tapatalk |
Oil cooler/Exchange 'O' rings |
See that is something I would not think of. Thanks. |
How about the front engine mount since you'll be there any way.
Use an airlift to vacuum and refill, they are a blessing. I recently bought the OEM brand knockoff and it works perfect, saved lots of time and made the effort easy and clean. 50 bucks.
Attachment 22392 Sent from my iPhone using Tapatalk |
Thanks for all of the suggestions.
Motor mount was done last year so I don't need to work on that. I do have the UView 550000 Airlift for the coolant exchange. I've never used it so we'll see how that goes. Ordered the low temp thermostat, underdrive pully and belt. |
| All times are GMT -8. The time now is 04:06 PM. |
