Old 04-13-2016, 10:25 AM   #1
Perfectlap's Avatar
How do you clean your drain holes?
I was cleaning the top this weekend, when I lowered it halfway to clean out the clam shell I noticed that the drain holes on both sides were completely clogged leaving a three inch puddle on either side. The water was blue? Must have been from the foam. I grabbed a Bic pen and managed to squeeze it in the drain hole which let out the water. But the passage has angle to it, when I tried to pull out the leaves and what looked like dirt from a flower pot, with my finger I couldn't really get it out so its more than likely going to get backed up again. Anyone have a good method to clean this?
BORN: March 2000 - FINLAND
Old 04-13-2016, 10:34 AM   #2
911monty's Avatar
Consider yourself lucky! I had a small acorn get under the foam tray and in the drain below! Had to use a borescope to find it. Was able to remove it with one of those extended reach tools (link below) without tearing everything apart.
Easiest way to clear I found is to use a short length of something like plastic refrigerator water supply tubing. The drip tray drain hose end is right in the mud flap/ trim piece. It is white 3/8" plastic tbg. Simply insert the small tubing up from below and flush out with some water until clear. Easy.
http://www.mscdirect.com/product/details/06574966 it is not magnetic. It has 4 small hook teeth that open when depressing plunger.
PS Buy the drain covers. They save a lot of grief. https:https://www.ecstuning.com/Search/SiteSearch/Drain_Cover/ES2065693/
PSS: Check your front drains, I think they actually collect leaves easier than the rear and are harder to inspect. I made a pair of stainless wire screens for my front drains. They work very well.
Old 04-13-2016, 01:22 PM   #3
Perfectlap's Avatar
Awesome. Where did you get the screen material?
These drain plugs have become an issue. Last year I had two inches under the passenger seat and carpeting behind the seat was always wet.
Old 04-13-2016, 02:32 PM   #4
911monty's Avatar
What I did was bought a stainless strainer basket from Walmart. Couple bucks and plenty of material. Cut the strainer into 2 pieces and used a 1/2" bolt as a form. I then formed the screen around the bolt into a mushroom shape. cut the stem end down to about an inch of length. You can then pull a bunch of loose strands from the stem piece so it fits down into the drain. The mushroom end keeps leaves off the drain and now I have not found water up to the brake booster anymore! Well when it does rain!
The design is not the best IMHO. The foam tray merely guides the water to the actual drain bucket under it, and that of course overflows right into the passenger compartment and you can't see what is really in the actual drain. In my case there was an acorn in there that was a perfect stopper. I now have the drain covers that should keep everything nice and clean.
Old 04-13-2016, 03:20 PM   #5
911monty's Avatar
The screens
Couple pics. One shows the screen working. They were made quickly to test the concept, but have been working so well I haven't made more.
Old 04-13-2016, 06:27 PM   #6
Toilet paper.
Old 11-05-2018, 03:05 PM   #7
Good ideas. But if you have your car outside, even with a cover, put some absorbent material or chamois behind both seats to give you an advance warning about where it’s about to happen. If they get damp or wet it’s a wake-up call. Not a solution, but it will wake you up!
Blackcloud is offline   Reply With Quote
Old 11-05-2018, 05:40 PM   #8
i saw someone in the Facebook Porsche Boxster 986 group recommended using a flexible trombone cleaner to push all the way down and through the drain pipes to make sure they're clear. It seems like a good idea as long as pushing the cleaner through doesn't disconnect the drain tube from the drain fitting.
Old 11-06-2018, 02:15 AM   #9
"50 Years of 550 Spyder"
10/10ths's Avatar
I have these...
...https://www.********************************************** ******.com/product/PK98XDRAIN.html
Work great.
Old 11-06-2018, 06:41 AM   #10
^ replace ************************************************** with
s unco as t pa r ts
"Cool Prius!"
- Nobody
Old 11-06-2018, 07:45 AM   #11
10/10ths's Avatar
Sorry
Yes. Suncoast.
Darn cookies.
Old 11-06-2018, 08:01 AM   #12
There Is No Substitute.
rick3000's Avatar
If you are trying to post the 987 drain covers, the Part Number is: 987 561 487 00, runs about $14 for a set.
Part Numbers save money!
Old 02-15-2020, 01:57 PM   #13
If anyone could help me w a photo of a correctly assembled pushrod attached to the triangle pivot plate and the silver ball (cup end) for a 06 boxster (987.1) that would be appreciated ... i am plugging that drain hole - could be cause of some of my backseat carpet passenger wetness issues ..
ISO100 is offline   Reply With Quote
Old 05-31-2020, 07:59 AM   #14
Since this thread helped me make the video, figured I'd post a link here... made a DIY video on cleaning the drains with input from you guys!
https://youtu.be/Hz-C9pkMnDk
1998 Boxster
2015 BMW M4 Dinan Stage 3
2016 BMW S1000XR
2015 Ninja 300
TTGator is offline   Reply With Quote
Old 06-01-2020, 12:39 PM   #15
Finnegan's Avatar
Are front drain screens available, or does everyone just make their own?
Old 06-01-2020, 12:40 PM   #16
Good question. I've never heard of either (one being available or someone making one).
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 06-02-2020, 09:46 AM   #17
BYprodriver's Avatar
I keep mine clean by not allowing anything to get in them.
Old 06-02-2020, 10:49 AM   #18
Finnegan's Avatar
I was all set to buy the drain screens.. until I saw the outrageous shipping charges.
Old 06-02-2020, 01:48 PM   #19
M9G
2002 2.7 Boxster in green
M9G's Avatar
I did all mine a couple of days ago and a length of rubber fuel pipe is perfect for the job to get round the bends
M9G is offline   Reply With Quote
Old 06-03-2020, 07:50 AM   #20
Yeah, just do what 911monty suggests. Cheap. Easy. I made 4 of them in very little time. Mine are "innies" as opposed to monty's "outties" but they work just fine. I thought about buying the official screens and just balked at spending that kind of money on something that's so easy to make myself for a couple bucks.
