05-28-2020, 08:31 AM
Can SOMEBODY, ANYBODY Help Me With Keyfob?!?
Other than a dealer, that is. I know I can bring it there...
05-28-2020, 08:34 AM
Who's askin'?
what do you need done? you need a new key fob programmed? you'll need someone with a PST2 or a PiWiS. If you were in Utah, I could help you out.
05-29-2020, 02:25 PM
Hi maytag, yes. Well, sort of - I have two fobs that are not working anymore. I think I can get the buttons aligned and the red light flashes but they don't actually do anything.
That make sense? Where in Utah are you? I am sometimes in Park City
05-29-2020, 06:04 PM
Damn Yankee
If the actual key works, and only the switches on the fob are not functioning, there may be a problem with broken solder joints on the circuit board.
Forum member particlewave can help you out here.
Just sayin'.........
TO
06-05-2020, 10:24 AM
Thanks, TeamOxford
06-05-2020, 10:36 AM
Just in case you didn't know about this, here's a little info from the owner's manual:
06-13-2020, 01:18 PM
Yes, thank you 78F350 - I noticed that. Something is up with the circuit itself, probably need the buttons re-soldered. Haven't heard back from @particlewave... thoughts?
06-26-2020, 07:06 AM
I have the same issue, but one key works fine and the other doesn't.
It flashes the same as the one working, I changed the battery and still does not work with the car. I just bought the car a week ago and the owner said maybe a battery.
Possibly have to go to the dealer to get it programmed, I don't really need the key now but would still like both keys to be working.
06-26-2020, 07:22 PM
A key fob can only be programmed to he car if you have the barcode for it. Otherwise, you are SOL
06-27-2020, 08:59 AM
I had the same issue when I purchased my car. One key fob worked, one did not. I ended up going to the dealer to have a new key fob paired with the car. Rick
06-27-2020, 08:54 PM
Where would I find the barcode, I have I think everything the new car came with (all the manuals & literature) also have a radio code card, but don’t see any kind of bar code.
06-28-2020, 02:17 AM
1998 Boxster Silver/Red
The barcode is on a sticker under the driver's seat. You may have to remove the seat. Good luck.
1998 Porsche Boxster
06-28-2020, 07:51 AM
That is good info to know . So there is a sticker attached to the bottom of the driver's seat with the barcode of the original key/s ?
06-28-2020, 08:31 AM
Two codes are needed to program a replacement key fob. One is for the fob itself and the other is for the car. The fob code comes on a tag with a new unit. The car code may be found under the driver's seat (I'm not 100% sure about this) or a Porsche dealer can provide it. The dealer just needs the Vin to get the code. They may be resistant to giving it out, but keep pushing to get it. I've had several fobs programmed in the past at an independent shop which used an Autologic computer to do the job. Takes about 10 to 15 minutes per fob.
'87 951
'01S 986 (Sold after 16 years ownership)
'78 924 (carburated; sold when moving to CA)
06-28-2020, 09:14 AM
I was being a wise-ass. No, there is no sticker under the seat.
06-28-2020, 09:19 AM
Dammit, Starter! I believed it too! Should have learned by now!
2010 Subaru Forester
06-29-2020, 06:43 AM
There are no security codes under the seat. That would kind of defeat the purpose of them.
You have to get the security code from a Porsche dealer. You most likely will have to prove you own the car. I got my codes, but it took a few weeks, the dealer said they had to get Porsche USA approval first
06-29-2020, 08:09 AM
And there you have it.
The registered owner must be at the dealer to effect the service.
06-29-2020, 08:10 AM
Originally Posted by piper6909
LOL. Did you go out and look under the seat?
06-29-2020, 10:18 AM
Ha, glad I didn't see this until this morning. Would have spent time in the blazing heat removing the seat to find a code.
