Old 05-28-2020, 08:31 AM   #1
Can SOMEBODY, ANYBODY Help Me With Keyfob?!?
Other than a dealer, that is. I know I can bring it there...
safesaxbdd is offline   Reply With Quote
Old 05-28-2020, 08:34 AM   #2
Who's askin'?
maytag's Avatar
what do you need done? you need a new key fob programmed? you'll need someone with a PST2 or a PiWiS. If you were in Utah, I could help you out.
Old 05-29-2020, 02:25 PM   #3
Hi maytag, yes. Well, sort of - I have two fobs that are not working anymore. I think I can get the buttons aligned and the red light flashes but they don't actually do anything.
That make sense? Where in Utah are you? I am sometimes in Park City
Old 05-29-2020, 06:04 PM   #4
Damn Yankee
TeamOxford's Avatar
If the actual key works, and only the switches on the fob are not functioning, there may be a problem with broken solder joints on the circuit board.
Forum member particlewave can help you out here.
Just sayin'.........
TO
TeamOxford is online now   Reply With Quote
Old 06-05-2020, 10:24 AM   #5
Thanks, TeamOxford
Old 06-05-2020, 10:36 AM   #6
Motorist & Coffee Drinker
78F350's Avatar
Just in case you didn't know about this, here's a little info from the owner's manual:
Old 06-13-2020, 01:18 PM   #7
Yes, thank you 78F350 - I noticed that. Something is up with the circuit itself, probably need the buttons re-soldered. Haven't heard back from @particlewave... thoughts?
Old 06-26-2020, 07:06 AM   #8
I have the same issue, but one key works fine and the other doesn't.
It flashes the same as the one working, I changed the battery and still does not work with the car. I just bought the car a week ago and the owner said maybe a battery.
Possibly have to go to the dealer to get it programmed, I don't really need the key now but would still like both keys to be working.
Jasper7821 is offline   Reply With Quote
Old 06-26-2020, 07:22 PM   #9
On the slippery slope
JayG's Avatar
A key fob can only be programmed to he car if you have the barcode for it. Otherwise, you are SOL
2004 996 Targa Tip
Instructor - San Diego region
Old 06-27-2020, 08:59 AM   #10
Rickvd's Avatar
I had the same issue when I purchased my car. One key fob worked, one did not. I ended up going to the dealer to have a new key fob paired with the car. Rick
Rickvd is offline   Reply With Quote
Old 06-29-2020, 06:43 AM   #11
JayG's Avatar
There are no security codes under the seat. That would kind of defeat the purpose of them.
You have to get the security code from a Porsche dealer. You most likely will have to prove you own the car. I got my codes, but it took a few weeks, the dealer said they had to get Porsche USA approval first
2004 996 Targa Tip
Old 06-29-2020, 08:09 AM   #12
1998 Boxster Silver/Red
And there you have it.
The registered owner must be at the dealer to effect the service.
1998 Porsche Boxster
