Old 05-27-2020, 06:39 AM   #1
soft top removal
Good morning!
I've got the engine installed and running, and now need to fab new engine covers!
I'm interested in removing the entire top to make access easier. I've got the transmission arms removed, and was able to take out the 3 bolts on each side where the top pivot mounts.
This allowed the top to move around a small amount, but it would not go far enough in any direction to come off. Like the pivot plates were hitting on something.
Has anyone else carefully accomplished temporary removal? I'm not opposed to removing more parts as necessary but also don't want to just start taking off parts I don't need to.
The Bentley book doesn't seem to cover removal, just all of the adjustments and such.
Thanks in advance!
outsidetheboxster is offline   Reply With Quote
Old 05-27-2020, 07:59 AM   #2
78F350's Avatar
Have you removed the B pillar carpet piece? Here's a picture. Note that I'm pointing to one screw that needs to be removed and there is a small bolt (8 mm?) up top going to the roll bar. Also see the orientation of the plastic tabs - The piece pulls up, then away.
I've also seen a pair of smaller screws holding some top frames on. I'll see if I can find a detail of that.
Old 05-27-2020, 11:43 AM   #3
Will there be cake?
tonythetiger's Avatar
https://youtu.be/mkTLoHlhGPY
and Ive pulled the the clamshell before, its esay.
Old 05-27-2020, 12:31 PM   #4
Awesome! Exactly what I needed. Thanks so much.
