Old 05-13-2020, 02:43 PM   #1
Water pump plastic broken
finally able to get the water pump off, one screw took two days...when i finally got the water pump out, the plastic impellers were broken off, and the crankshaft looked like where the impellers hit are damaged...crank case??? what now? this im sure has happened to others, had a hard time removing the gasket as it was connected to other parts of the engine, like the last person to change the pump attached it to the engine somehow...
Tlightfo is offline   Reply With Quote
Old 05-13-2020, 03:13 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
Read through the attached with pictures. It should answer most of your questions. The forum host, Pelican Parts, has a quite a library of DIY articles for these vehicles.
https://www.pelicanparts.com/techarticles/Boxster_Tech/34-WATER-Thermostat_and_Pump/34-WATER-Thermostat_and_Pump.htm
Old 05-14-2020, 01:21 AM   #3
traveno's Avatar
Some pictures may help us. Sound like there's going to be fine plastic pieces in your coolant. I think Porsche designed these impellers to be fibrous because they anticipated this happening when a water pump fails. Better than having a metal impeller dig itself into the wall of the case.
I'd give that article a look-over. Then I'd flush my coolant and inspect it for those impeller pieces. I'm not exactly sure what you mean by a damaged crankshaft/crankcase? A picture of this would help.
A thorough flush and a new water pump should fix your problem.
2001 Tiptronic S in Speed Yellow
traveno is offline   Reply With Quote
Old 05-14-2020, 09:07 AM   #4
78F350's Avatar
A major concern would be flushing the cooling system within the engine to make sure that the pieces of the impeller are not blocking any of the passages.
The engine that this pump came from had a blockage that most likely caused a cracked cylinder head. This is the worst water pump I have seen:
The other big concern, as you mentioned, is that the pump can damage the crank case. With a non-metal impeller that is unlikely. As the others have said, post a picture if you can so we can get a better idea of the extent of the problem.
Here's a video I recently made when I was replacing a water pump with a bad bearing. This one had a metal impeller. There may be some useful info for you:
Old 05-14-2020, 09:32 AM   #5
And DO NOT use any type of sealant on the water pump housing; totally unnecessary and can actually cause problems.
Old 05-15-2020, 12:47 PM   #6
Pity they hadn't been so insightful when they decided to fit a wheel bearing in the engine 😉
jonogt6 is offline   Reply With Quote
Old 05-15-2020, 01:04 PM   #7
piper6909's Avatar
:Mic drop!:
