Old 05-04-2020, 07:26 PM   #1
Is this a coolant leak or A/C?
I have distilled water in my coolant system right now so I知 unsure. I知 having lots of problems with the car right now. Flushing intermix from failed oil cooler, etcetera,...
So is this location have anything to do with a/c? Or should I suspect coolant hose?
-J
2001 Boxster S. Meridian over Boxster red.
Studio City, Los Angeles area
Gone to IMS heaven, 2001 Lapis blue over blue.
Junkley is offline   Reply With Quote
Old 05-04-2020, 07:32 PM   #2
911monty's Avatar
Coolant leak. That is where the expansion tank overflow hose drains. Typically coolant cap related. Unless you replaced coolant tank recently with something other than OEM.
Old 05-04-2020, 08:15 PM   #3
I知 thinking drain hose and coolant tank is rearward of this spot. I do sincerely appreciate the response.
-J
Old 05-05-2020, 08:26 AM   #4
Rob175's Avatar
Last year my 20 yr old coolant tank developed spider cracks that would expand and leak once the car got up to temperature. I discovered this after I began seeing the same leak you pictured. BUT my trunk carpet was dry as a bone. So I removed all the trunk carpet/liner, AND the trunk's synthetic raised floorboards ....and discovered a pool of coolant sloshing around between the trunk ribs. It"s that same coolant that would slowly find it's way to one of the rubber plugs, leak through and land on the garage floor, just like your pictures.
Pull everything out of the trunk and look for a pool of coolant there. My "indy" shop replaced the tank with an OEM tank from Pelican....labor and parts were about $800.
Unfortunately, two months before the coolant tank leak, I had the water pump fail and it was replaced for about $900 (parts and labor). I could have probably saved a few bucks if I replaced BOTH at the same time.
Good luck.
Rob175 is online now   Reply With Quote
