Old 05-04-2020, 10:13 AM   #1
Brian Minson's Avatar
LN Engineering IMSB
While tearing down the 3.2 out of the Budget Boxster I noticed someone at some point in time had installed an LN Engineering IMSB. I was wondering if I could pull and reuse it in the current engine that is in the Boxster?
Brian
Brian Minson is offline   Reply With Quote
Old 05-04-2020, 10:42 AM   #2
Multi-Boxer Driver
Deserion's Avatar
So you didn’t actually pull the IMS bearing. but can just lift the complete shaft out? Not sure if it can be reused as removing the bearing from the shaft effectively damages it.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 05-04-2020, 02:01 PM   #3
Ask LN, bet they say no. And not for financial reasons but from damage pulling it.
Old 05-04-2020, 02:33 PM   #4
Brian
Extracting the bearing will damage the cages and possibly the balls as well, which will lead to premature failure, and which is why you should never reuse an extracted bearing.
The ONLY retrofit that is known to be reusable is the IMS Solution, because it has no moving parts.
Old 05-04-2020, 06:57 PM   #5
If you sacrifice the shaft and cut it in halves you can press it out using a tool that sits on the outer ring of the bearing. This way it won`t get damaged. The shaft is worth more than that bearing though.
