Old 05-04-2020, 03:33 PM   #4
JFP in PA
Originally Posted by Brian Minson View Post
While tearing down the 3.2 out of the Budget Boxster I noticed someone at some point in time had installed an LN Engineering IMSB. I was wondering if I could pull and reuse it in the current engine that is in the Boxster?
Brian
Extracting the bearing will damage the cages and possibly the balls as well, which will lead to premature failure, and which is why you should never reuse an extracted bearing.
The ONLY retrofit that is known to be reusable is the IMS Solution, because it has no moving parts.
