Old 04-20-2020, 06:20 PM   #1
What materials are used in stock exhaust?
Pulling apart the underside of my '99 to for a clutch, IMS, and RMS replacement. The underside and exhaust components were in generally good shape (42K miles and vehicle sat in the garage a lot for the past decade).
Exhaust bolts etc were a little rusty but came free with a little penetrating oil and patience.
The midpipes and muffler are dull and have some light surface rust in some areas. I'd like to clean things up and/or refinish and have a few questions:
1. Stock manifolds are cast iron, correct?
2. Muffler is stainless, correct? What about the u-pipes and clamps?
3. What about the midpipe and cat housings? Stainless?
The bolts that are pressed into the midpipes are a little rusty. They could be re-used but would prefer to replace them. Any words of advice about if that's possible?
geekdaddy is offline   Reply With Quote
Old 04-20-2020, 09:11 PM   #2
1999 base
Meir's Avatar
All the components you mentioned, are 309 stainless steel. Parts that get hotter, will look darker. The mid pipe bolts can be pressed out ( penetrating oil and bench vice with a socket will do the job). Replace them with SS (304 grade preferably) bolt and nuts.
Old 04-20-2020, 10:25 PM   #3
jaykay's Avatar
You may want to put in a stud kit for the installation of manifolds
986 00S
Old 04-21-2020, 11:04 AM   #4
Thanks for the info -- perfect. I will clean things up and try pressing the studs -- and replace with stainless!
Old 04-23-2020, 11:39 AM   #5
FYI since may be helpful to others. I rented a tie rod puller from O'Reilly's ($45 deposit which is refunded when you return it). It worked perfectly to push the bolts out of the midpipes with minimal drama and no need to pound things with a hammer.
My '99 is exceptionally clean underneath. Spent most of it's life in a barn when not driven it's 40K miles in northern CA and Boise, ID. But the exhaust bolts were too rusty for my taste.
It's definitely been a good day. Also extracted the manifold bolts without any drama or breakage. Heads were rusty but hadn't lost their shape. Soaked them in penetrating oil for a few days and used my 1/4 drive cordless impact driver on 'em. Easy-peasy...
