Old 03-29-2020, 05:24 AM   #1
Ignition Switch/ Key Question
Hi guys - this may be a dumb question, but here I go!! I am going to have to have a new ignition switch installed. Will my existing keys work, with no reprogramming or anything? Thanks.
David Preston
2008 Cayman S
por356c is offline   Reply With Quote
Old 03-29-2020, 06:01 AM   #2
KevinH1990's Avatar
https://www.pelicanparts.com/More_Info/4B0905849MY.htm?pn=4B0-905-849-MY-INT&gclid=Cj0KCQjwjoH0BRD6ARIsAEWO9DsZw81yQYccCnkx51Ln ImPrkg_m0KzMeY5DvRexlNUS43cXss_6QS0aAvGuEALw_wcB&KeepHeader=Y&ByPassCat=Y&null=
If you are installing only the electrical portion of the switch (as shown in the link), your key will work.
Old 03-29-2020, 07:41 AM   #3
Thanks Kevin. I just sent you a PM. Thanks.
David Preston
2008 Cayman S
Old 03-29-2020, 08:04 AM   #4
KevinH1990's Avatar
Check out this post: Ignition switch replacement
It has information about a special screwdriver that may make the DIY replacement of the switch a bit easier.
