Old 03-21-2020, 04:08 PM   #1
Boxster mainenance
What is the "ususal and customary" service fee from independent Porsche mechanic for replacement of a starter motor for 1998 Boxster? A range would be helpful.
THANKS
Enameldust is offline   Reply With Quote
Old 03-21-2020, 07:29 PM   #2
Damn Yankee
TeamOxford's Avatar
A Porsche indie should charge $100-$120 per hour labor. There may be a one hour minimum charge. If you have a good established relationship with the shop you may be able to get away cheaper, as the job can be done in less than an hour.
A Porsche dealership will charge about $180 per hour labor, one hour minimum charge, possibly take longer than an hour, and then add on additional "shop fees" for rags, coffee, fingernail polish, etc.
Just sayin'........
TO
Old 03-21-2020, 09:53 PM   #3
A reasonable shop will charge 2 hrs labor + $300 for the part, so expect a total around $500. Don't be shocked if someone quotes up to $700 total ($300 labor + $400 parts).
So an expected range is $500 -$700. If you can get a quote for under $500 from a Porsche-specific shop, that's a pretty good deal.
Old 03-22-2020, 06:36 AM   #4
1998 Boxster Silver/Red
Why don't you do it yourself? You could have the old out, and the new in... in ~hour if you're prepared going in.
I done it in my carport... and am preparing to do it again. Maybe today.
This is the vid I watched... followed his instructions... a breeze.
https://www.youtube.com/watch?v=eJ9qnnf2kWU
1998 Porsche Boxster
Old 03-23-2020, 10:29 AM   #5
I got the original rebuilt (about $160 CDN) at a specialty shop for starters and alternators and managed to install it myself as well following the same YouTube channel from Burner. Replaced the AOS and cleaned the air intakes while I was at it.
nsantos44 is offline   Reply With Quote
