Old 03-07-2020, 11:25 AM   #1
Zzorro's Avatar
Convertible top - Strange issue - video link - SOLVED
Posted in technical Chat. See there for more details.
https://youtu.be/57yfndEJDsY
98 Boxster - Ocean Blue metallic. Bringing it back to life and having fun doing it!
20 Harley Streetbob -
Zzorro is offline   Reply With Quote
Old 03-07-2020, 09:53 PM   #2
looks like the motor/gear is not engaging well
saw this on youtube also and maybe you can get an idea.
https://youtu.be/dRRddWmayJE
ndfrigi is offline   Reply With Quote
Old 03-08-2020, 07:57 AM   #3
Zzorro's Avatar
Thanks. Yup, watched that one and it was helpful. The gears seem to work, I did test them before linkages were connected to the top. Full range of motion with no bouncing or strange noises.
I believe something is telling the motor to stop and start. Perhaps the sensor behind the drivers side left shoulder. I'm going to play a bit more with that one, see if that has something to do with it.
Old 03-09-2020, 09:56 AM   #4
1998 Boxster Silver/Red
Have you tried swapping relays? Might be the culprit if everything else seems to be in order.
1998 Porsche Boxster
Old 03-11-2020, 06:31 AM   #5
Zzorro's Avatar
Good point. I'll have to check I guess. I'll report back.
Old 04-01-2020, 08:38 PM   #6
Zzorro's Avatar
Well I replaced the relay and still had the same issue.
So I decided to play with the sensor over my shoulder. I "pulled" and held it towards the front of the car ever so slightly and I had full range of movement. Opening and closing. So I guess I know what the issue is now!
Still have a bunch of things I need to set. And the roof movement is jerky. So I bet there is some alignment I need to do. But it's getting there.
Old 04-03-2020, 07:27 PM   #7
I used my social distancing time to pull my top transmission today. The passenger side plastic gear was cracked and split. I'm ordering new gears. I hope I can get the other side back in time. That is where the limit switch is and I can't find any alignment marks. Mine behaved a lot like that b
MrBen is offline   Reply With Quote
Old 04-04-2020, 12:29 PM   #8
Zzorro's Avatar
I decided to go thru a complete reconnection today following the factory manual. It seems like that has fixed the issue completely. For those that want it, the manual reference is 61 77 05.
I'm pretty pleased with myself on this.
Old 04-05-2020, 04:03 AM   #9
Awesome! Nothing like getting everything back to normal.
