Old 03-03-2020, 06:28 PM   #1
ISSIMI
Help identifying IMS bearing
I'm interested in picking up a 987.1 S MY2006
Previous owner says the bearing has been replaced. Can someone identify from the pic if the bearing is aftermarket and if the engine is a split case or sealed bearing(M96 or M97)?
The part # on the IMS flange reads 99602406
Most_Wanted is offline   Reply With Quote
Old 03-04-2020, 05:35 AM   #2
If that center bolt nut is 22MM, which it looks like it is, it is the non serviceable third design IMS bearing, which would be correct for a 2006 engine. I seriously doubt it has ever been replaced.
Old 03-04-2020, 06:21 AM   #3
The 987 IMSB is indeed non-serviceable, but also a non-issue.
I would, however, be skeptical of a seller that says it has been replaced.
'97 - Silver (rebuilt/stripping)
'99 - Black (rebuilt/sold)
'01 S - Rainforest Green (daily)
'03 S - Orient Red (sold)
Fiddlebog is offline   Reply With Quote
Old 03-04-2020, 08:31 AM   #4
being so clean, there is the possibility that the previous owner changed the IMS 'flange only' with the improved seal as the IMS itself cannot be removed without complete engine disassembling as mentioned below...
Old 03-04-2020, 11:43 AM   #5
ISSIMI
Great, I was hoping it was the larger updated IMS bearing. I read, in rare cases the MY06 can still potentially have the smaller single row bearing used in 2001.
Yea I told the owner too, if it is a sealed case bearing, I doubt it's been replaced. Just to clarify current owner stated the previous owners to him replaced the bearing. He said it was the first owner that stated the bearing was replaced. I'm dealing with owner number 3.
Old 03-04-2020, 12:01 PM   #6
Most Wanted (..!)
IF by any chance you still have Not installed the gearbox yet, you may want to remove the outer seal on the IMS bearing to allow the engine oil to lubricate the bearing.
But.. to do it properly, first you will need to lock the crank at TDC, lock the camshafts, remove the tensioners and THEN, remove the flange so you can remove the seal from the IMS.
Old 03-04-2020, 12:02 PM   #7
Here's what the small OEM serviceable IMS bearing flange looks like from a 2005 987. I agree with others that it's unlikely the bearing was actually replaced. LN Engineering and some other replacement bearings usually come with their own IMS bearing flange with their name stamped on it. The bigger factory bearing is much more reliable and removing the bearing seal may improve its lubrication.
RobT
Sent from my Pixel 3 using Tapatalk
RobT987 is offline   Reply With Quote
