Old 03-03-2020, 04:00 AM   #1
Need help with Boxter S Seats
Hi,
Mu name is Mickey and new to this site. Last May I purchased a 01 Boxter S that was a in poor condition. It is up and running and one of the last things I need is new seats. I found a beautiful set of seats on c list. Here is the problem. My car has full power memory seats and an electrical box under the drivers seat. The new seats from on 03 are manual front and back and electric up/dn and tilt I guess?? Maybe heated?? The plugs are identical except the drivers seat has a 2nd set of wires that plug into the electrical box under the seat. The quantity of wires are different though in the new seats as the plugs are the same. I have the seats removed from the car and don't know the next step. If anyone has any experience with this it will be greatly appreciated as I feel stuck for now, I even thought of going to an upholster to switch out the fabric?? modonnell9@comcast.net. (pic is of new seats)
Thank You
Mickey
modonnell9 is offline   Reply With Quote
Old 03-04-2020, 05:20 PM   #2
KevinH1990's Avatar
I sent an email to you with a pdf as an attachment. The attachment shows how to swap the seat backs and seat bottoms of your new 2-way power seats on to the bases from your full-power seats. Unfortunately, the pdf is too big to upload here.
Your new seats have seat heaters. If your original seats have seat heaters, that will be an easy connection.
Porsche made the "full power" seats in two versions - 8 way power and 12-way power. The 12-way power seats add a powered lumbar support to the 8-way seats. If you had the lumbar support in your original seats, you will need to swap the upholstery from the seat back of your new seats to the seat back frame of your original seat if you want to retain the lumbar support. Unless you have worked with "hog rings" you may want to leave that task to a pro.
Good luck with your project. I have adapted an 8-way power passenger seat and a 12-way powered driver's seat to my car which originally came with two-way powered seats. I also installed the seat heaters. You have a much less complicated project.
