Old 11-20-2019, 07:30 PM   #1
More of a truck guy
Part number - Door anchor for mirror control trim
I need the part number of the plastic inserts, that fit into the door, that allow the triangle trim that holds the side mirror remote control to be attached. Mine have become brittle and have cracked, and the triangle trim won't stay attached.
I have tired to find the part number, but have been unsuccessful.
For those of you that don't know, they look very similar to the top part of plastic anchors that you insert into drywall, that allows you to insert a screw. I have even tried that, but cant find anything that is the right diameter.
2002 Boxster S 6 Speed
TNT79Bronco is offline   Reply With Quote
Old 11-20-2019, 07:59 PM   #2
piper6909's Avatar
Is this what you're looking for?
https://www.pelicanparts.com/More_Info/99950765140.htm?pn=999-507-651-40-OEM
Old 11-20-2019, 08:13 PM   #3
I think OP means those blue sockets. that you press the tabs into.
'97 - Silver (rebuilt/stripping)
'99 - Black (rebuilt/sold)
'01 S - Rainforest Green (daily)
'03 S - Orient Red (sold)
Fiddlebog is offline   Reply With Quote
Old 11-20-2019, 08:14 PM   #4
More of a truck guy
No. Thank you for responding. They are a little plastic “tube” with a flange head on it.
Old 11-20-2019, 08:16 PM   #5
More of a truck guy
Exactly!! Thank you for responding.
Old 11-20-2019, 08:20 PM   #6
piper6909's Avatar
These, then?
https://www.pelicanparts.com/More_Info/191853615A.htm?pn=191-853-615-A-M58
Old 11-20-2019, 08:23 PM   #7
I'm sorry I can't be more helpful. I usually default to the Porsche-supplied parts catalog when looking for part numbers. That or brute force whatever keywords I can think of into google.
I do have some potential solutions though. The '97 I'm currently gutting also apparently had a problem, and the previous owner had stuck some hot glue in there. It was a real pain getting out.
Otherwise, if you can't find the parts elsewhere, I'd be happy to try popping the ones I have out and sending them to you.
Edit-Piper is clearly much better at the internet than I am.
Old 11-21-2019, 04:29 AM   #8
piper6909's Avatar
Not necessarily, I just happen to have a pdf copy of the parts catalog that I found online, probably on this forum. Once I can recall the source, I'll post the link.
Old 11-21-2019, 04:57 AM   #9
piper6909's Avatar
Fond it!
https://www.porsche.com/all/media/pdf/originalparts/usa/986_USA_KATALOG.pdf
Check page 250, I believe you're looking for #1 on the illustration, which is part #191 853 615 A
Found here:
Old 11-21-2019, 06:12 AM   #10
Fond it!
Found here:
yeah I've got it saved as a bookmark; super important resource. I was just looking at the wrong assembly.
Old 11-21-2019, 05:25 PM   #11
More of a truck guy
Those look like they might work! Heap enough to get a few and give it a shot. Thanks!!
Old 11-21-2019, 05:29 PM   #12
More of a truck guy
Thanks ya’ll. I looked at the manual (each page 8-o ) and could t find the part. I saw the old assemble, that had the triangle cover, but could t find the inserts. Musta missed it :-/
Thanks again.
Old 11-21-2019, 05:54 PM   #13
piper6909's Avatar
Welcome! Glad to give back to the forum!
