Old 10-22-2019, 02:31 PM   #1
2002 s 3.2 engine
Does anybody know whether I can use 3.2 engine From 2002 can be used in 2003 or 2004 ?
Smhube00 is offline   Reply With Quote
Old 10-22-2019, 03:28 PM   #2
No, different variocam/engine management
Old 10-23-2019, 05:33 AM   #3
I'm guessing by your question that you need a 03/04 3.2. You'll have better luck finding a 02-05 3.6 for about the same price. More power is always a good thing
Woody
Old 10-23-2019, 05:38 AM   #4
Pelican has a great article about engine swap compatibility here:
https://www.pelicanparts.com/techarticles/Boxster_Tech/11-ENGINE-911_Engine_Swap/11-ENGINE-911_Engine_Swap.htm
But I agree with Woody; slap a 3.6 in there!
'97 - Silver (rebuilt/stripping)
'99 - Black (rebuilt/sold)
'01 S - Rainforest Green (daily)
'03 S - Orient Red (sold)
Fiddlebog is offline   Reply With Quote
Old 10-23-2019, 08:46 AM   #5
BYprodriver's Avatar
Then it won't bolt right in without drilling & tapping new thread holes.
Old 10-23-2019, 03:20 PM   #6
Thanks guys
I have 2002 s with 3.2.
I had accident.
I am looking into taking the engine from the 2002 and find a roller to put that engine.
Old 10-23-2019, 05:00 PM   #7
Artist, 986S tinkerer
NewArt's Avatar
They changed the engine configuration in 2003. The newer 3 chain engine uses motronics 7.8.
Old 10-23-2019, 06:47 PM   #8
NewArt is correct. If you want an easy plug&play option for a roller, you'll want a 2000-2002.
Old 10-24-2019, 03:30 AM   #9
That's only if you're using a boxster intake. Super easy if you want to use the 986 intake but you're missing out on some hp if you skip on the 996 intake
Yep, life will be much easier using a 2000-02
Woody
Old 10-24-2019, 01:33 PM   #10
I guess I have start looking harder for 2000-2002
Old 10-25-2019, 03:37 AM   #11
Here’s a car for your engine. Tucson is a bit of a haul though.
https://tucson.craigslist.org/cto/d/2001-porsche-boxster/7002359724.html
