Which IMS solution?
Betting this has been asked a thousand (ten thousand times), but thought maybe it was time for a refresh.
I am getting ready to replace/upgrade the IMS in a 2000 Boxster I just bought (2.7, 90K miles).**** Oil and filter were spotless, but want to put the pin back in the grenade before it goes off (car is flawless but sale price still reflected a $2-3K discount for an IMS replacement).**** I plan to****do the****clutch and RMS at same time as well. I have a shop ready to do the work, but they want me to pick and buy the solution (this will be first time in 20+ years I've taken any of my cars to a shop -- just seems to make sense in this case given the cost of the tools to do a IMS, and the fact that I don't have a lift and don't want to do everything I have to do with say my '93 911T -- like removing bumpers, etc -- to drop the drivetrain when the car is only on jackstands -- I'm embarrassed and ashamed at how old and lazy I am getting). First question:**** not sure if it is a single or dual row, is any way I can figure it out before dropping tranny and inspecting the IMS retainer?**** I know there are a lot of opinions about the accuracy of engine number lists, etc.**** Haven't crawled under it yet to find the engine number, but previous owner (longtime -- as in 40 or 50 years -- PCA member) said it was a November 2000 build.**** So let the opinions fly . . .**** Second question:**** what solution should I use? So solutions as I see it (from cheapest to most expensive) are: 1) OEM replacement 2) LN engineering dual row****ceramic (still a sealed bearing, right?) 3) Technofix DOF (I would like this except it is relatively new and not sure of the quality of the bearing given how little they are****charging for it -- a case of reverse supply-demand curve) 4) LN plain bearing (like 10x the cost of an OEM bearing) Is this the list or are there other solutions? The mechanic I found does a lot of track cars driven here in Austin at COTA, has done 50+ Boxster IMSs over the years (probably even more 996/997s?), mostly the LN ceramic dual row, only a handful of the LN plain bearing upgrades (said it's overkill for all but the hardest driven track cars) and no OEM (I am guessing) or TechnoFix DOFs.**** He seems to prefer the LN ceramic as he's never had one fail****in 10 years, but still put the final decision/choice****on me. Personally, I like the TechnoFix DOF, but it's pretty new, and the bearing itself concerns me (I've bought wheel bearings that cost more than what they want for the open bearing itself, so how could can it be is what causes me pause). Again, let the opinions fly . . . |
Ok I'll jump in even though I have not done the IMSB
Personally I would go LN Dual Row. Now your year could be either dual or single and you can't tell until you pull the Fly wheel and I believe the IMSB cover will indicate which. Now it's my understanding that LN makes a Dual row for both an original dual row replacement and a dual row that can replace the original single row. Just my thoughts but it's your $$$$ Oh and this question may have been asked in the Billions |
The LN ceramic retrofit bearings are not sealed, they are open to allow mist lubrication.
While the IMS Solution may cost more, it is the only permanent replacement for the IMS bearing. |
I haven't done one either and probably won't since I have a Tip. (I'll just replace the motor if it goes)
Having said that, I've done some research on it, and the European Parts Solution makes the most sense to me. It uses an internal oil feed modification, and roller bearings. It costs $579 - $739, depending on motor. The one for your motor should cost $579. https://www.europeanpartssolution.com/ims-bearing-upgrade-kit The IMS Solutions bearing is a plain bearing similar to a rod bearing and has an external oil feed modification. It costs over $1800. They both have 5 year warranties. They both claim to be permanent bearing fixes. |
OMG, yet another solution to think about!
Opening the link now . . . |
OK, a really cool solution: oil gets in the IMS tube anyway so may as well force oil thru it to lubricate the bearing.
Looks like the oil pump is on the other end of the engine though, so more work for my mechanic (wonder if he'll be willing to try this one). Is the oil pump hard to access from underneath with the car on a lift? They say 5,000 installed. Anyone know someone who's installed this? I am not a spirited driver, but I wonder if oil starvation on hard cornering could be an issue? And what does it do to oil capacity -- do you need more now that you're partially filling the tube with oil squirting down it? |
I don't know whether it's bad or not to flood the IMS tube with oil. It is my understanding that oil finds its way in there anyway and gets trapped. Maybe allowing it to circulate and refresh itself may not be such a bad idea. It's just a thought, I'm in no way an expert in this matter. But the concept makes sense to me. And BTW, Pelican Parts is an EPS Retailer. They sell the kit for $696.00 https://www.pelicanparts.com/More_Info/99610590102EPSINT.htm?pn=996-105-901-02-EPS-INT&bt=Y&fs=0&SVSVSI=986M |
My solution would be to just drive the thing
How is this still “a thing”?
The IMS Solution to invest in is the “IMS Solution” developed by Jake Raby of Flat 6 Innovations and LN Engineering.
Use the Google. It works. It is a permanent fix. Just do it. I did, and 35,000 miles later I’m still driving the piss outta her with zero worry and sleep great at night. Now, about your oil and tire choices... |
The IMS Solution pumps oil into the bearing from the outside. You don't want that oil going through the bearing into the IMS tube with nowhere else to go because it'll remain there and get stale. That's why they have to use a plug. The EPS Solution is to feed oil from one end of the tube, out the other end, into the bearing and back into the pan. This allows for circulation. |
Ok now that this has been solved, can we talk about really important stuff Should we be removing the warning labels from our sun shades???? |
I've got to just say that my 1998 (all stock) Boxster w/ manual trans and 87,000 summer driving only miles, has the orginal IMS and I have no plans to touch it. I've talked to 3 Porsche dealer veteran mechanics and a large Chicago "indi" shop specializing in Porsche's, Audi's and Mercedes......in total they claim to have only seen 3 Porsche's that have suffered a IMS failure in the last 15-20 yrs.
To be fair, a couple did say that if one was to do the clutch, then it's probably "not a terrible idea" to change out the IMS bearing but none thought it was something that needed to be done proactively. They believed it all depends on the overall condition and value of the car as to if it makes sense to JUST do the IMS. I suppose everyone has their own take on the subject....at one time there was a survey/poll on this Forum but I can't seem to find it. |
I see no reason to suggest that the EPS isn't as good a solution as any other.... and it is most CERTAINLY "good enough". My own decision with the used motor I just installed in my car was to just leave the IMS alone. There are WAAAY too many other things that can take the motor out, for me to start worrying about something with such a statistically-low failure rate. |
Wait. Did someone say oil and tires?
OOPS......typo....it's a 1998 not an 89....LOL
But what does LWFW mean? Left Wing ______ ______ ? Quote:
Maytag....
...Why must you disparage folks who have purchased parts from Jake Raby with great success and bring a political analogy into this discussion?
How does that help the collective? |
Regarding the political analogy, I was the butt of the joke, but I found it funny and a rather good analogy and funny. So I wasn't offended in any way, so lighten up a bit. :cheers: |
Rather, I'm disparaging those who close their minds to any other knowledge, experience or solution. Your own post: "... use the Google..." is already condescending, and you go on to actually say that there's only one solution. So I'll ask your question of YOU: how does that help the collective? Sent from my SM-G970U using Tapatalk |
Easy.....
.....He asked which solution to buy. I told him which solution to buy.
I told him to "use the Google" because there is a wealth of information out there on this subject. Simple. |
"LN Engineering and Flat 6 Innovations have secretly been working on a solution (pre-dating the introduction of the single row bearing IMS Retrofit kit) to the bearing failures experienced in model year 2000 through 2005 intermediate shafts using the single row ball-bearing, dubbed the IMS Solution." Source: https://myemail.constantcontact.com/Whats-s-New-At-Flat-6-Innovations.html?soid=1107025842595&aid=DM3W5Z9OmA k |
So he has zero interest in L/N with Charles.... and has zero interest in THE IMS SOLUTION ? if that's true, then we're not talking about raby anyway, because we've been talking about the purveyor of that product. And 10; piper already set ya straight, below. I don't know why you'd want to continue being offended? Sent from my SM-G970U using Tapatalk |
And yes, he has no interest in LN, that is Charles Navarro's business. And Piper had not "set me straight" about anything; he is entitled to his opinions, and I am equally entitled to disagree with them. But if anything, with years in this business, I have learned to stop talking when someone does not want to hear a dissenting opinion, regardless of how much experience it is based upon. |
https://myemail.constantcontact.com/Whats-s-New-At-Flat-6-Innovations.html?soid=1107025842595&aid=DM3W5Z9OmA k He wrote it himself that he worked with LN Engineering to develop the IMS Solution. Its not opinion, JFP. My only opinion is that I don't think he did it so LN gets all the profits, do you? |
And yes, I know LN is Charles' enterprise, but it sure seems they blur the lines regularly. I don't believe for a moment that Raby has no vested interest in the IMS SOLUTION. And likely some other products as well. But that's not a problem. Everyone seems to misunderstand my comments about JR/CN/LN. I think they're awesome, frankly. I think they develop great stuff for us all. I think their knowledge is HUGE. and I've heard they're also really nice guys. Where I get less enthusiastic is with the zealots. The people who quote raby like scripture. The ones who think that if raby said it then it's above question. The ones who like to name-drop to try to win an argument. And yes, the ones who think raby has no agenda. He most clearly DOES have an agenda, since he makes his living off of people believing his way is best (if not "only" way). Sent from my SM-G970U using Tapatalk |
And let me set the record straight, I think the IMS Solution is a fine product. I'm just making the argument that it's not the ONLY permanent solution.
Most likely I will not replace my IMS bearing since I have a Tip. But if I had a manual and I had to change the clutch, I'd probably do it and use the EPS solution. It has fewer parts that could fail, like the external flex hose, and it costs less than 1/3 of the IMS Solution. The lower cost makes it a much better insurance policy. <-- And that's my opinion. |
Maytag...
....I never posted that I was offended.
Go back and read. Before this gets outta hand, I am leaving this thread. For folks who want to know my opinion on this subject, please just search all of my posts. I have written extremely detailed posts on my wonderful experience with Jake Raby and Flat 6 Innovations and how wonderful the entire experience has been working with him and his folks. Am I a Jake Raby fanboy? Absolutely. He has been awesome to deal with. He has always answered all of my questions immediately and has been there to back up everything he has done. I really do not understand why anyone would be less than enthusiastic discussing Jake Raby and company. My personal experience has been spectacular. Again, I never said I was offended. Cheers. |
As for the Solution, if memory serves, Jake and either developed or was in the process of developing the Solution when Charles approached him about the idea for an open ceramic hybrid bearing, which after substantial testing at Jake's facility become the LN retrofit product(s). Jake completed his development of the Solution, and then patented it before LN began production of it and released it to the public. As the patent holder, I'm sure Jake gets a residual off the Solution kits that LN produce; which is exactly why patents exist. As for my comment about your "opinion", that was directed at the EPS product, not Jake or Charles relationship. They are both business men, and as other have commented, very nice guys as well. But as astute business men, I would hardly expect them to act otherwise. |
If nobody's offended, and everybody agrees so splendidly, then why are you leaving the thread?
I just shake my head sometimes at people who talk in circles. I'm sure your experience has been great. Many other's (including my own) has been "spotty" at best. That's fine..... every business has its struggles, and issues, and even its outliers / anomalies. Again: if nobody is offended then I don't know why you'd have to leave the thread. Sent from my SM-G970U using Tapatalk |
| All times are GMT -8. The time now is 10:55 PM. |
