Old 08-22-2019, 11:40 AM   #1
Ciao's Avatar
Rear Thump
I can't put my thumb on it. I have an 01, 40K Miles and I keep hearing a thump in the rear when I go over bumps. Is it the convertible top, rear suspension? Or something else?
Thoughts?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 08-22-2019, 01:02 PM   #2
piper6909's Avatar
Thoughts?
Most likely your rear lower control arm bushings. unfortunately they're not replaceable, you'd have to buy new arms.
https://www.pelicanparts.com/More_Info/98633104307M80.htm?pn=986-331-043-07-M80&bt=Y&fs=0&SVSVSI=
Old 08-22-2019, 02:50 PM   #3
Has the center motor mount ever been changed?????
Old 08-22-2019, 03:52 PM   #4
Ciao's Avatar
No; not to my knowledge. Bought the P car from brother in law with only 37K miles 2 years ago
Old 08-22-2019, 04:35 PM   #5
piper6909's Avatar
The sad part is that with the LCA bushings and the Center Motor Mount, you can't tell if they're bad until you removed them.
My money is still on the LCAs I mentioned on my prior post. I had the same noise where I couldn't tell if it was suspension or the convertible top frame. I did some research and found that they were common culprits so I changed them and noise gone! Although now I'm starting to get some noise from the fronts...
Old 08-22-2019, 05:00 PM   #6
The rubber center on mine was completely gone at 47000 miles.
I heard dull clunks when I would slowly go over speed bumps
If the problem is your center motor mount you can sort of feel it when you let out the clutch or went taking off from a dead STOP.
Old 08-23-2019, 09:37 AM   #7
Ciao's Avatar
98-3/4% confident it's not motor mount.
Old 08-23-2019, 09:50 AM   #8
Ciao's Avatar
I am leaning towards the LCAs as the source.
Old 08-23-2019, 01:02 PM   #9
Ciao's Avatar
Could it also be the drop links?
Old 08-23-2019, 02:45 PM   #10
Probably rear track arms. If you replace do the drop links to. I did, and it solved the problem. The bushings wear out over time.
Blackcloud is offline   Reply With Quote
Old 10-06-2019, 02:20 PM   #11
Ciao's Avatar
Turns out the rear clunk/thump noise was from the rear storage cabin. One of the locking nuts/screw was loose and rear cabin was making the thumping noise through bumps...Ha!
Old 10-08-2019, 01:03 PM   #12
Lucky you!
