Thread: Rear Thump
Old 08-23-2019, 08:50 AM   #8
Ciao
Ciao's Avatar
The sad part is that with the LCA bushings and the Center Motor Mount, you can't tell if they're bad until you removed them.
My money is still on the LCAs I mentioned on my prior post. I had the same noise where I couldn't tell if it was suspension or the convertible top frame. I did some research and found that they were common culprits so I changed them and noise gone! Although now I'm starting to get some noise from the fronts...
I am leaning towards the LCAs as the source.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
