09-20-2019, 04:49 PM
#1
Artist, 986S tinkerer
tire moving on rim at the track
So, I'd heard of this; someone had posted here on the forum. Curious, I marked my track wheels with new tires (RE-71R) before a 2-day event. This is the right rear
wheel after 2 days:
09-20-2019, 06:31 PM
#2
That's mind-blowing. The question is, was it the acceleration or braking that did it? If that's a pick of the right tire, it would be braking. If it's the left tire, then it would be acceleration.
09-20-2019, 07:09 PM
#3
Actually. I think it’s the left rear. I get my hands mixed up!
09-20-2019, 07:23 PM
#5
1997 Tip, 2018 Macan
The original pic doesn't look like all that much of a shift. I remember other posts' showing +/-6" IIRC from track days. I would imagine the rears show far more of a shift than the fronts?
EDIT: Maytag looks about right.
09-20-2019, 07:34 PM
#6
Originally Posted by NewArt
Actually. I think it’s the left rear. I get my hands mixed up! ��
Then it must be happening during acceleration. I was expecting the opposite. I didn't think they had enough torque to do that.
But then again, it looks like all 4 tires moved, so it has to be during braking. Are you sure it came from the left (driver's) side?
09-20-2019, 07:41 PM
#7
Originally Posted by maytag
I noticed each pair of tires rotated in opposite directions. Is one pair fronts and one pair rears?
09-21-2019, 05:33 AM
#8
Yeah, I thought that the previous post was an anomaly, but I now see that this is common for track tires. Maytag’s pictures bowled me over! The movement of my tires is negligible in comparison.
09-21-2019, 07:33 AM
#9
Who's askin'?
The guys at the track that day told me that's very common. I'd have never believed it, had it not happened to me.
And piper, as for what tire is what in my photos, I don't recall now. But I'd think it only makes sense that the rears spin under power (so the wheel turns "forward" in the tire) and the fronts under braking (so the tire turns "forward" on the wheel).
Dunno.
09-21-2019, 09:27 AM
#10
Well, so much for precision wheel balancing!
09-21-2019, 09:57 AM
#11
Who's askin'?
Yup. That's exactly what I said in the other thread. Never paying to balance track tires ever again
09-21-2019, 10:50 AM
#12
So, do street tires do this in day to day driving? Anyone checked?
09-21-2019, 11:54 AM
#13
Dunno.
If we know which side the wheels/tires came from and the direction of the rotation, we can determine if it's braking or accelerating causing it. I suspect that even an S doesn't have enough torque to cause this under acceleration.
My theory is that it's caused by breaking, and the front tires rotate more than the rears, because the fronts brake harder.
I probably won't track until next year, and if I do I probably won't drive it as hard as some people on here because I don't have the skills. So it would be great if someone would try the experiment and note which corner each tire/wheel was on. Maytag, would you be so kind?
09-21-2019, 01:43 PM
#14
Who's askin'?
Well what I do know, is that you're looking at a rear laying flat and a front from the same side leaning against it, in both images. I just don't remember which image is left or right.
As you can see, they're rotating opposite directions on the wheels.
There's very, VERY little braking going on on the rear wheels, especially at the racetrack where brakes are usually on VERY HARD, or not at all. There is SUBSTANTIALLY more torque being applied to the rear wheels under acceleration than under braking.
09-21-2019, 03:37 PM
#15
Ok. I didn't think they would put out that much torque to rotate the tires on the rims. You know more than I do, so I'll take your word for it.
09-21-2019, 03:43 PM
#16
So, judging from the position of the valve stems, unless the rear tires rotated over 270 degrees, the top pic should be the tires from the left, correct?
09-21-2019, 11:34 PM
#17
How in the world does this happen and not break the bead/seal? Are the tires getting hot enough to somehow soften the bead enough to allow this? That’s pretty crazy. I’ll have to mark mine next time out...
09-22-2019, 08:35 AM
#18
I’m shocked that you guys are so shocked by this.
Seriously...
09-22-2019, 10:25 AM
#19
Seriously...
I'm shocked that you're shocked that we're shocked!
Seriously, I'd never think that was possible unless I saw the pics. But then again, I've never tracked.
09-22-2019, 11:05 AM
#20
Who's askin'?
Seriously...
I know..... everyone at the racetrack was so dismissive of this, when I was surprised by it. They've seen it for so long, at such extremes, they couldn't imagine I didn't know about it.
Now I do. ;-)
