09-26-2019, 12:13 PM
Winterizing
It's almost time for some of us Northern Tier types to be thinking about winterizing our Boxsters. One thing that is often forgotten is topping off your blinker fluid before putting her away. That way, you won't be plagued with a faulty turn signal next spring. You're welcome.
09-26-2019, 12:33 PM
Do you have to use Genuine Porsche fluid, or would off-brand do? And while you're in there, you might as well check out the back-up light solenoid.
09-26-2019, 01:26 PM
1998 Boxster Silver/Red
Just winterized mine.
Top down. Humps on.
1998 Porsche Boxster
09-27-2019, 07:05 AM
2003 S, Arctic Silver, M6
Also it's a good time to ensure that the twin muffler bearings are well greased and turning smoothly.
09-27-2019, 06:24 PM
Damn Yankee
Check to make sure both rear fog lights are working. If one is out, you can be f****d. There may be a recall for your particular year.
Just sayin'...........
TO
09-28-2019, 02:19 PM
A hardtop and dedicated snow tires, a pair of driving gloves, no special fluids...
09-28-2019, 08:04 PM
Need For Speed
Originally Posted by piper6909
Of course it has to be Genuine Porsche fluid. What are you, some kind of heretic? Just don't get blinker fluid in your eye it will cause uncontrollable blinking.
2003 Boxster S
10-01-2019, 07:42 AM
Don't forget to check your bonneville inflation tube and grease the gastranomical clutch bearing.Two things that are easily overlooked.
99 Roadster base / 5 SP Tiptronic
18" Turbo Twist wheels / Arctic silver W/Black leather Int
Rear wing W/Brake light / 47,000 miles
Side skirts / Bought from original owner
10-01-2019, 07:49 AM
Who's askin'?
Not to be the grammar police again, but gastronomical should be capitalized. Mr. Gastronomy was the inventor of that bearing, which allowed for the first time the use of a hemispherical bearing in a dual-axis rotational plane. Pretty ingenious, really.
Don't know why, but reading about him always made me hungry. Haha.
10-01-2019, 07:52 AM
Porsche "Purist"
Also make sure you retract your radio antenna and rotate your lug nuts.
1987 924S. 2002 996TT. PST-2
10-03-2019, 11:36 AM
In seriousness, what do people do with their top? Keep it up, but unlatched?
10-03-2019, 12:00 PM
That's what I do. My 99 still has the original top and it is as tight as a drum.
10-08-2019, 02:06 PM
I keep it latched, but if you have any windshield dings, or a crack, loosen the top by opening the top latch. When it gets cold, the top will shrink and put additional pressure on the windshield which could cause it to crack. This happened on my MG. Small stone ding at the bottom of the windshield caused a 6 inch crack over the winter.
10-13-2019, 06:22 PM
And if your coolant level is low, replenish it with some dehydrated water.
2004 Boxster S, 6 spd, Triple Black
1986 944 Turbo (sold in 1988)
Since then, a 300ZX, a few BMW 3 Series, a few VW's
10-13-2019, 06:23 PM
Here's the way I'm gonna winterize my Boxster: Drive it (as long as there's no snow or ice)
Driving it saves a lot of hassles and headaches and work.
10-13-2019, 07:59 PM
Do you dehydrate your own or buy it bottled?
10-14-2019, 07:17 AM
I store my 1998 in my attached garage with it's convertable top fully up and locked in postion. It's a newly replaced top w/glass window, as of 2 years ago. I also add a few extra pounds of air pressure to the tires. During the winter months is Chicago....IF the weather cooperates (ie: no snow, ice or salt on the road) I will usually try to run it up and down the expressway, once during the winter, for about 50 miles.) Other than that, it stays covered in my garage.
