Old 12-08-2019, 06:25 PM   #1
Need For Speed
KRAM36's Avatar
Originally Posted by PaulE View Post
Hi Woody, I'm working on a pair of headlights and when I'm finished I'm going to use this Eastwood 2k clear for the UV sealing. When I get the lenses completely clear and scratch free, should I then go back and wet sand them with 800 grit again before spraying them?
No, 800 grit would leave deep scratches. Use 2000 to 3000 grit.
2003 Boxster S
Old 12-08-2019, 06:38 PM   #2
Thanks I thought I saw 800 somewhere. If the lenses are polished after the 2000 or 3000 will they be too smooth for the clear coat to adhere?
Old 12-08-2019, 07:21 PM   #3
1500 or 2000 is fine. It's very important that you do very light coats and leave time for them to dry in between coats. If you put it on too heavy the clear will get spider cracks.
Woody
Old 12-08-2019, 07:27 PM   #4
Once you get enough light coats on, then you can start laying it on thicker so you get less orange peal.
Woody
