Old 09-05-2019, 09:03 PM   #1
Cleaning The Rear Glass Window
Can someone tell me the easiest way to clean the inside of the glass rear window. There doesn't seem to be a way to have easy access to it. Is it easier to partially open the top, and if so, how much?
2004 Boxster S, 6 spd, Triple Black
1986 944 Turbo (sold in 1988)
Since then, a 300ZX, a few BMW 3 Series, a few VW's
BoxMann is offline   Reply With Quote
Old 09-05-2019, 10:52 PM   #2
Multi-Boxer Driver
Deserion's Avatar
I remove the wind deflectors and have at it.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 09-06-2019, 06:37 AM   #3
Tailwind's Avatar
+1 what Chris said
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
Tailwind is offline   Reply With Quote
Old 09-06-2019, 12:08 PM   #4
Cunningr's Avatar
+2 wind deflector removed!
Old 09-07-2019, 08:25 PM   #5
Thanks, Chris. Worked like a charm.
But I was having trouble getting the deflector back in place. It didn't easily snap back into place, I had to press real hard on it, and I still don't think it's in the correct position. Shouldn't it pop back in easily?
Old 09-09-2019, 12:32 AM   #6
Multi-Boxer Driver
Deserion's Avatar
Sometimes it can be a bit finicky to get back in, try moving the latches a little when reinserting.
I also remembered one way I cleaned the window - roof in service position and the glass up against the rollbar. Was already in the engine bay anyhow.
-Chris
Old 09-06-2019, 10:45 PM   #7
A8ked's Avatar
I've put the top in the service position, unhooked the bottom and reached under and up. It's a pain, next time I will go with the removal of the wind deflectors.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
