Old 08-29-2019, 12:00 AM   #1
Scuffing Noise
Hi Chaps
I wonder anyone can shed any light on a scuffing noise coming from the ns rear wheel of my Boxster S.
It doesn't do it all the time but sound a lot like the disc is catching on the disc cover plate. Starts when going round a bend and the load is on that side of the car.
The car has recently had new discs and pads all round. Iv had it to two garages but the can see any problem.
There eis not play in the wheel bearing or bushes
Next step may be the remove the disc backing plate then try it
YellowS2000 is offline   Reply With Quote
Old 08-29-2019, 04:43 AM   #2
piper6909's Avatar
Another member had a spring loose inside the emergency brake drum and it was making noise. You may want to check your drum brakes.
Old 08-29-2019, 09:40 AM   #3
Thanks for your great reply. i hadn't though of that, Ill pass that on to my mechanic.
Old 08-29-2019, 12:08 PM   #4
2003 Boxster
I had this on mine. It was the dust plate on the back of the disc. There isnt much ‘move’ in it but it got a press/push and noise gone. This could be a solution.
Agree with the spring comment also.
Leo G is offline   Reply With Quote
Old 09-03-2019, 02:06 AM   #5
thanks ill get it looked at, its driving me insane
Old 09-03-2019, 09:15 PM   #6
I had this recently and it was the parking brake cable rubbing on the wheel.
lskolnick is offline   Reply With Quote
Old 09-04-2019, 11:48 AM   #7
I get this sometimes and it's really annoying. Its definitely the back plate behind the disc.
Bizarrely enough, if I reverse for a metre or so it clears and doesn't come back for several weeks.
jonogt6 is offline   Reply With Quote
Old 09-05-2019, 06:50 AM   #8
I'm going to try that lol
Old 09-04-2019, 01:11 PM   #9
I had it too, I was sure that it wasn't the plate behind the disk, but when I removed it the sound went away..
