Old 07-26-2019, 08:26 AM   #1
Franco's Avatar
Oil Filter Housing Surprise
Did an oil change today and found these plastic pieces in oil filter housing.
Anyone have an idea what they could be and do i need to put the car on sale
1997 Boxster with 98000 KM.
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
Franco is offline   Reply With Quote
Old 07-26-2019, 08:28 AM   #2
Artist, 986S tinkerer
NewArt's Avatar
Bits of chain guide ramp. Plastic guides need replacing.
Old 07-26-2019, 11:31 AM   #3
Franco's Avatar
Thanks NewArt,
Nice to chat with someone from Montreal, do you know where I can get this done in our area.
2014 Honda CRV
Old 07-26-2019, 11:48 AM   #4
NewArt's Avatar
Call Andrew at AGM (previously WeTune). Very capable, honest and not priced like the dealership! Specialises in Porsche and racecars. Phone 514-633-1497, he's located in Lachine.
Old 07-26-2019, 07:59 PM   #5
Franco's Avatar
Thanks NewArt, do you know if this repair is possible without removing the engine?
Franco
2014 Honda CRV
Old 07-27-2019, 06:48 AM   #6
Franco's Avatar
Hi, I have searched for hours trying to match these plastic pieces to all the chain related parts (photos) and I'm not convinced they are from the guides.
More opinions please
2014 Honda CRV
Old 07-27-2019, 09:50 AM   #7
ccjazz's Avatar
Disregard, was thinking cooling system
'01 Boxster S (purchased new) triple black, litronics, cruise, heated seats,18's.
ccjazz is offline   Reply With Quote
Old 07-27-2019, 09:56 AM   #8
If those pieces are indeed from the water pump and found their way to the oil filter housing, then you probably do need to list your car - as a roller.
Old 07-27-2019, 10:16 AM   #9
Agree with you Franco.... normally the chain guide are more greenish/white plastic. But I maybe wrong here. Have you looked at the bottom of the filter housing to see if the spring valve mechanism is there and still complete ?
pomerlo is offline   Reply With Quote
Old 07-27-2019, 10:41 AM   #10
Notice that they are all identical. That’s a big clue.
It’s definitely not chain ramp material.
It’s not water pump vanes.
It’s also not from anything in the filter housing.
Old 07-27-2019, 11:11 AM   #11
Franco's Avatar
Hi Pomerlo,
I did verify the bottom of the housing and the mechanism is still there.
Maybe these pieces are part of the housing serving as reinforcement seat for the spring and washer.
A diagram of the inside would clear up a lot of maybe's
2014 Honda CRV
Old 07-27-2019, 11:15 AM   #12
Franco's Avatar
Can they be from the inside of the oil pan?
2014 Honda CRV
Old 07-27-2019, 11:34 AM   #13
I went through the PET and could find nothing matching the “s” curve. They do look like vanes of some type, but I can’t say for sure.
Hopefully someone with M96 engine tear down experience will have an idea.
Old 07-27-2019, 12:00 PM   #14
78F350's Avatar
Here's a pic of the big chain ramps that lead up to the heads. Note that the cracks can often form at a sharp right angle. Color is dark brown, not black.
Here's the chain guides on the cam chain adjuster. I don't think the fragments are from these.
I have a partially disassembled engine if anyone has a suggestion of another part to look at.
Old 07-27-2019, 12:50 PM   #15
It’s hard to tell from the OP pics, but notice he has one on its edge so you can see the “s” curve that each piece has (if you look closely, you can see the curve in the others, as well).
How do the scavenger pumps work? I seriously doubt that they have plastic vanes, but just an idea.
Old 07-27-2019, 01:12 PM   #16
911monty's Avatar
Anything in the oil filter first has to get picked up from the sump, pass thru the oil pump pickup screen then get macerated thru the oil pump, not much chance of that happening with pieces that large. What type filter housing are you running?
Old 07-27-2019, 01:24 PM   #17
steved0x's Avatar
I had a piece in my used oil that even had a partial part number. The only match was the oil pickup tube. Ultimately I finally figured it was a piece off the oil filter end cap that broke off when I was cutting the ends to unroll it and fell down into the pleats. So depending on the mechanism you used to unroll the pleats to examine them, maybe it is a piece broken off in that process?
Old 07-27-2019, 01:51 PM   #18
Franco's Avatar
Hi, this is the housing on my Boxster.
2014 Honda CRV
Old 07-27-2019, 02:20 PM   #19
78F350's Avatar
I'll offer you $1,500 USD for your broken Boxster.
...But, I think you just need a new oil filter canister.
Old style is smooth on the bottom:
New style canister has vanes at the bottom:
Vanes are "S-curved". Vanes are past the oil pick-up screen. Get a look at the bottom of your canister. Broken vanes?
Old 07-27-2019, 02:25 PM   #20
Nice detective work!
I checked my old canister and it doesn’t have those.
