Old 07-11-2019, 09:57 AM   #1
Window does not go down 1/2"
I recently changed my passenger door window regulator and now it does not drop a half inch when I touch the door handle. It wants to move, I can hear it. But, it is as if there is some slack in the cable that gets absorbed. Any ideas on how to remedy this?
1stSP is offline   Reply With Quote
Old 07-11-2019, 11:28 AM   #2
BYprodriver's Avatar
Search the forum to see how others have remedied that ?
Old 07-11-2019, 12:13 PM   #3
Will there be cake?
tonythetiger's Avatar
ooops, sorry i didn't read you replaced the regulator already...what rex said.
you need a new regulator, 99%
search the forum, ive been very happy with the URO aftermarkets
Old 07-11-2019, 01:33 PM   #4
I recall reading some posts regarding this topic. I believe someone mentioned the cable does stretch. I remember they had a hack but someone else mentioning the correct replacement part wasn’t too expensive. Sorry I do not have the link to the post
gsy4771 is offline   Reply With Quote
Old 07-11-2019, 02:04 PM   #5
See if this helps-
Window Drop Issue-
Window regulator permanent fix for stretched cable
dsjwilson is offline   Reply With Quote
Old 07-11-2019, 06:35 PM   #6
1997 Tip, 2018 Macan
rexcramer's Avatar
After you X/O the regulator, (new or used) did you reprogram each door? If it's used, the cable may already be stretched beyond repair.
IIRC, you need to run the window all the way open and hold the button five seconds then run the window all the way closed and hold the button for five seconds.
