Old 07-10-2019, 02:03 PM   #21
"50 Years of 550 Spyder"
10/10ths's Avatar
Here's a screen shot...
Old 07-10-2019, 02:42 PM   #22
Originally Posted by 10/10ths View Post
.....Oil is cheap.
Engines are expensive.
I don't think changing my oil with Porsche Branded for $160 will make my engine last any longer than M1 or Castrol. My next oil change I will use 5w-50 as recommended though.
ExplorerLyon is offline   Reply With Quote
Old 07-10-2019, 03:13 PM   #23
10/10ths's Avatar
Follow your heart...
...I actually use this:
https://www.drivenracingoil.com/dt40-5w-40-synthetic-street-performance-oil.html
Old 07-10-2019, 03:31 PM   #24
I've been using Shell Rotella T6 for the last year. The engine used to have a quiet tick, but that went away with this oil and the engine just feels happier.
Old 07-10-2019, 04:12 PM   #25
Check out the project farm on U tube he does some simple test with motor oil's and a bunch of other everyday products with interesting results,..
flmont is online now   Reply With Quote
Old 07-10-2019, 05:03 PM   #26
Wow......all these replies and I dont think even two people are using the same product. The options are all over the map. Good knowledge gain here.....glad I went for the quickie post.....
Anyone else have over 150k on your 986?
The reason that I purchased such a high mileage 986 was the previous owner was a Porsche mechanic. Many of the common issues have already been repaired.....and fingers crossed I can keep up with future maintenance...
Box7774 is offline   Reply With Quote
Old 07-11-2019, 01:21 AM   #27
10/10ths's Avatar
It’s really very simple.....
.....Don’t suffer analysis paralysis.
Just pick any good oil in 10-40 or 5-50 that you can easily source and fits your budget and CHANGE that oil every 3,000 miles.
Replace the water pump and Air/Oil Separator every four years.
Replace the brake fluid every two years.
Be prepared for ignition coil and cam chain tensioner replacement at some point down the road.
That’s it.
Use Shell gasoline and let her warm up properly before driving the snort outta her.
Don’t worry. Just enjoy the machine.
Welcome to the party, Pal!
Old 07-11-2019, 09:53 AM   #28
It is very easy to over analyze anything but unfortunately " what is the right oil " is not a simple one part answer . Let's face it ANY oil will work and if you change it often enough you will probably get by . However to REALLY know what's going on with any oil is to have it lab analyzed . And you have to do multiple samples . Here is an example: after Jake built my engine and it was broken in he suggested I use Driven DT40 synthetic . I did and we started doing oil analysis . My seat of the pants reaction was hey this oil works great because I wasn't burning much and the motor sounded good . But after a few samples Jake didn't like certain properties he was seeing in the oil reports .
So he had me switch to Brad Penn 10w40 semi-synthetic and we have done a few more samples , he stated my oil analysis is perfect and has been over several samples . I believe in my case the DT40 was having some separation issues , certain properties of the oil were being affected by the fuel . It's all way over my head but Jake has done probably 10,000 oil samples on every oil out there so if he recommends BP for my engine that's what I'll use .
Keep in mind this is about MY engine in MY car after multiple oil samples . Your results may be totally different . If you like making decisions based on real evidence then do some oil sampling . If your not interested then go with what you like and drive it like you stole it . I see Particlewave is using Rotella , an excellent oil with high zinc/phosperous content due to it being a diesel oil . Nothing wrong with running it in gas engines . End of my story , sorry for the long reply .
rfuerst911sc is offline   Reply With Quote
Old 07-12-2019, 07:16 AM   #29
I will be honest with you guys......I have learned more about my new used car on this oil thread then I possibly imagined. I really appreciate the replies and added knowledge. Originally I was thinking that due to the high mileage that my car might benefit from a high mileage oil or viscosity.......u guys have given me plenty of options to chose from. This car is only driven for fun so not many miles per year.
Many thanks!!!!
Now where is that beer thing...........ahhhhh
Old 07-12-2019, 10:55 AM   #30
Not ANY oil! It has to be a synthetic oil and have the right viscosity. I choose to go by the recommended oils.
1941 Dodge Luxury Liner Coupe
Old 07-12-2019, 09:55 PM   #31
Need For Speed
KRAM36's Avatar
What did you end up going with?
I have 128K miles on my car, always used M1 0W-40, except one time I used either M1 5W-30 or 10W-30 and got horrible engine clatter at start up. By the end of the week I had drained the oil and put 0W-40 back in it. I'll not play with the oil viscosity again since the engine has done fine with M1 0W-40, so why mess with good results.
As for the oil filter, I use the K&N PS-7011 Pro-Series Oil Filter, usually off eBay or Amazon and bought a bunch of crush rings, I think it was 20 from Pelican when I was ordering some other stuff that got me free shipping.
2003 Boxster S
Old 07-13-2019, 06:59 AM   #32
bcrdukes's Avatar
What's wrong with extra virgin olive oil in your Porsche, folks?
2001 Porsche Boxster S
bcrdukes is offline   Reply With Quote
Old 07-13-2019, 02:14 PM   #33
I bought my car very recently and it came with some old paperwork. I know in the past it has been on Mobile One so for that reason I am just going to stick with Mobile One. Some of the replies mention Porsche now recommends a diff viscosity.....so thats my last desision....0W 40.....or 5W 50 ....not sure if M1 makes 5/50 or not. So ya...I havent got around to changing the oil yet. Just did the cigarette lighter conversion today. Have to replace the starter next I believe.
Old 07-13-2019, 05:29 PM   #34
Need For Speed
KRAM36's Avatar
Mobil 1 does have a 5W-50 oil for Porsche now, but it's hard to get here in the US and it's expensive.
https://www.mobil1racingstore.com/mobil-1-122075-oil
Oil specs. https://www.mobil1racingstore.com/Content/Images/uploaded/GLXXMobil-1-FS-X2-5W50.pdf
2003 Boxster S
Old 07-23-2019, 10:14 AM   #35
M2
Driven 5W-40 DT40 oil Joe Gibbs Racing
mcmike27A is offline   Reply With Quote
Old 07-23-2019, 06:33 PM   #36
MCMIKE.......U like that stuff? Sell me on it....I am a Redskins fan although not very proud of it......but the name Joe Gibbs still has some class
Old 02-03-2021, 10:41 AM   #37
piper6909's Avatar
Forgive me for reviving an old thread, but I didn't want to start 'another oil thread.'
So it's time for an oil change and I'm having a hard time finding the recommended (According to the manual for my climate, both above and below 50 degrees F.) 10w-40 grade in Mobil-1.
I know that now Porsche recommends 5w-50, but I didn't see any charts based on climate, and I find it hard to believe it's good for all climates, especially not for below 50 degrees F.
From my research on here I've seen people using 0-40, 10-30, 5-50, and other grades, some of which aren't even listed in the manual. Why such a variety of preferences when the manual seems quite specific?
Nonetheless, since 10w-40 is harder to find, am I safe using 5w-40, which is more readily available?
Thanks in advance!
2010 Subaru Forester
piper6909 is online now   Reply With Quote
Old 02-03-2021, 10:59 AM   #38
You would be far better off using Gibbs DT40, 5W-40 full synthetic with high ZDDP levels.
Old 02-03-2021, 11:55 AM   #39
piper6909's Avatar
Thanks, JFP. You've inspired me to do some research on ZDDP.
Old 02-03-2021, 07:15 PM   #40
Using Rotella T6 5w40 for at least 10 years on all cars with my family; SAAB turbo with 170K miles, BMW X5D35, VW Jetta EA211 and 97 Boxster. Just love this oil! It contains higher ZDDP than Mobil 1, got to be good for IMS bearing! Works great, reasonably priced, readily available, no complaints.
