Old 07-02-2019, 07:34 AM   #1
belt tensioner arm/pulley
I am trouble shooting an intermittent noise from the belts/pulleys. I removed the belt and ran the car without belts, no noise. I checked the pulley and rollers and did not find and real issues.
I put the belt back on a discovered that the tensioner arm is not moving the whole distance, about a 1/4 of an inch of travel can be pushed by hand. I am thinking that is the problem.
If so, is the solution a new tensioner arm or is this a lubrication issue?
Dvaid
Luckyman01 is offline   Reply With Quote
