Old 05-13-2019, 05:32 PM   #1
Strange behavior of door locks
Hello:
1997 Boxster, all stock, 32K miles.
All doors closed, top up & locked, hood and trunk closed tight. Hit the key lock on the key FOB. All locks go to lock position, park lights flash, 2-3 second later, door locks pop open.
Tried same configuration with manual key-turn to lock, all locks go to locked position, 2-3 seconds later door lock pop open.
I checked the microswitches in windshield frame for convertible top - behaves normally. Door windows appear to work normally.
I changed driver’s side window regulator about a year ago, reset limits and everything worked fine.
What could possibly be the problem??
Guidance to start troubleshooting this is appreciated.
Best regards,
J
boxster_nut is offline   Reply With Quote
Old 05-14-2019, 09:32 AM   #2
Ignition switch??
