Old 05-13-2019, 07:48 AM   #1
Rattly part on exhaust pipe
Hi all,
Noticed that my 986.2 is vibrating from the rear on startup/idling (prob does driving too, just can't hear it). It seems to be some metal cover of a pipe (exhaust i think)
In lieu of me not being mechanically minded and not knowing anyone who is, can someone point out if it is a potential problem or not.
there doesnt seem to be a 'cover' over the same exhaust pipe on the other side.
is there anything I can do to stop it vibrating, fixing it on or removing etc?
thanks in advance
thefunkygibbon is offline   Reply With Quote
Old 05-13-2019, 12:53 PM   #2
Will there be cake?
tonythetiger's Avatar
It is probably the heat shields on the cats, up by the manifolds and you need them. Look around on the forums, a common problem and several folks have reattached them by riveting metal and re-screwing them, or you can spend around 80? bucks each to replace them.
