Old 03-26-2019, 12:23 PM   #1
pidj's Avatar
Turbo Twist Shimmy
It appears that a PO may have hit a pot hole real hard on the passenger side of my 2001 986S.
Since I've had the car, approaching 75mph results in a shake until moving up to a higher speed. When I put new tires on, the installer identified that these two wheels are a bit out of round and needed to be balanced a bit special.
Question: is there good results with having a wheel guy true a turbo twist wheel or is it a 'good money after bad' situation?
Thanks!
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
Old 03-26-2019, 03:01 PM   #2
I'd suggest taking it in for an estimate. The OE cheap cast wheels may not even be repairable - but at least you'd know.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 03-26-2019, 03:48 PM   #3
The good wheel repair places will tell you if a wheel is bent or damaged beyond repair. I wrecked one of my front Lt. Alloy Carrera 18 inch wheels at VIR and it was beyond repair. I bought a used one from eBay that needed refinishing as well as truing. It was trued and refinished and is holding up well. It came out looking so good I had the other 3 wheels trued and refinished too. My car rides the smoothest it has ever been since I bought it in 2003. You should definitely find a good wheel repair shop and have it looked at. Some of the tire shops have relationships with good wheel repair facilities and may be able to help you find one.
Old 03-27-2019, 08:57 AM   #4
A8ked's Avatar
Thumbs up
I had a slightly bent front wheel too. I checked the local wheel straightening companies and they all wanted $125 or more to fix the bent wheel. I contacted Woody here on the forum and he sold and shipped me a good replacement wheel for a much better price! Drop him a PM.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
Old 03-27-2019, 09:01 AM   #5
pidj's Avatar
Yeah, that's the strange thing - they don't appear damaged, just what the tire center found when balancing new tires. I brought the car up from Indiana and those roads are not great, so it makes sense (about potholes)
Thanks!
Old 03-27-2019, 12:45 PM   #6
BYprodriver's Avatar
Always best to observe unknown wheels spinning on a wheel balancer without tires to see how out of balance the wheel is. This way you know if it's the wheel or the tire that needs attention.
Old 03-27-2019, 07:50 PM   #7
You can't rely on eyeballing it.
IMHO, you should get a Wheel PPI before buying used wheels.
2004 Boxster S, 6 spd, Triple Black
1986 944 Turbo (sold in 1988)
Since then, a 300ZX, a few BMW 3 Series, a few VW's
BoxMann is offline   Reply With Quote
Old 03-27-2019, 07:54 PM   #8
The Radium King's Avatar
i have nothing to add to this thread, but saw the title and thought you were starting a new dance craze.
https://youtu.be/jVShf4xrk94
Old 03-27-2019, 08:15 PM   #9
I've bent 4 wheels from going off track at high speed and had them all repaired. Sometimes the damage was visible and sometimes it wasn't (the wheel would always seem out of balance).
Find a high quality wheel repair service and they can certainly do the job.
This link has photos and even a video. Oh, and I cracked the oil pan too. That was a BIG hole. Spec Boxster Build
Old 03-27-2019, 08:29 PM   #10
AZ986S's Avatar
Hilarious!:dance:
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 03-28-2019, 04:56 AM   #11
Or discount the price for the possible cost of having the wheels trued!
