Old 01-31-2019, 11:21 PM   #1
Pinning gears on IMS?
Hi All,
I will soon get to start reassembling the engine and it is still a bit unclear for me why the valves were touching the pistons. This makes me wonder if my IMS gears are still aligned and not rotated with respect to the shaft. How can I test this? Also, since the IMS is out now, would it make sense to pin the gears?
Thanks for any input.
Homeoboxter is online now   Reply With Quote
Old 02-01-2019, 06:28 AM   #2
Hi All,
Yes...……….
Old 02-01-2019, 11:35 AM   #3
Yes...……….
All right, I`ll pin it then. Any idea about how to check the gear alignment? Also, there`s a punch mark on the external side of the largest gear, looks like a timing mark, any idea what that is referring to?
Thanks!
Old 02-01-2019, 02:07 PM   #4
Thanks!
No. We send our out to a shop that checks the gear indexing before pinning them. Never had a problem when they were done.
Old 02-01-2019, 02:11 PM   #5
BYprodriver's Avatar
Hi All,
Send it to LN Engineering
Old 02-01-2019, 04:50 PM   #6
lowpue's Avatar
Hi All,
I had a new(rebuilt) engine put in my boxster. Gear slipped and we thought the chain skipped a tooth so the timing was fixed. Then it did it again so the shop took a closer look and the IMS gear was slipping. It was sent back to the builder who pinned it. If yours is slipping you need to fix the timing and then pin.
2020 Taycan Turbo S - DD Rain
2015 Huracan - DD Sun
2002 Boxster - Play Car
2000 C2 Aero - Track Car
1965 Dodge Coronet 440 - Nostalgia
lowpue is offline   Reply With Quote
Old 02-01-2019, 08:48 PM   #7
Amazing.. I can`t turn the gears on the shaft by hand, but there has to be a reason why the timing was off. Thanks for the info.
Old 02-02-2019, 09:37 AM   #8
Useful video on checking alignment and pinning:
https://www.youtube.com/watch?v=XP6GwqLvD7Q
