Old 01-18-2019, 04:21 PM   #1
Artist, 986S tinkerer
NewArt's Avatar
What’s wrong with this picture?
Okay, for 15 points, can you spot the problem?
Old 01-18-2019, 04:32 PM   #2
78F350's Avatar
Is there a nut on that IMS center bolt? Wait... is there a bolt?
Edit: And it came from one of those silly cars that mounts the engine backwards (noticed tubing and harness).
Old 01-18-2019, 04:35 PM   #3
NewArt's Avatar
Haha, clever boy!
Old 01-18-2019, 04:40 PM   #4
Jager's Avatar
Whatever it is, it also took the Oil Cooler!
It is not going to look pretty inside that motor.
Jäger
300K Mile Club
Old 01-18-2019, 04:46 PM   #5
NewArt's Avatar
Look way down that tube and you will find the missing part!
Old 01-18-2019, 04:47 PM   #6
Is that a dual row IMSB and it still failed? Maybe your cylinders won't be scuffed if that is what was making the knock.
Old 01-18-2019, 04:49 PM   #7
The Radium King's Avatar
i can spot the problem - you haven't moved your new coffee table into the living room yet.
Old 01-18-2019, 05:16 PM   #8
NewArt's Avatar
No, it’s a single row.
Old 01-18-2019, 05:19 PM   #9
NewArt's Avatar
We’ll see. There’s always room for optimism.
Old 01-18-2019, 08:40 PM   #10
CEL P0306
Your engine fell out of your car.
aczyzewski is offline   Reply With Quote
Old 01-19-2019, 04:59 AM   #11
I m sorry to see that.
"YouTube Certified in Various Specialties"
Old 01-19-2019, 02:57 PM   #12
Well FWIW my IMSB looked similar. The only collateral damage to the engine was a timing chain paddle on the back of the engine, part of the oil pump and the IMS itself. The crank, rods, cylinders heads, etc were all good and reusable. I hope you are in the same boat. And my block is finally in transit back to my shop from LN with 3.6 Nickies installed..
Old 01-19-2019, 04:58 PM   #13
NewArt's Avatar
Thank you Paul for adding a sparkle into this dreary prospect!
Old 01-19-2019, 05:49 PM   #14
elgyqc's Avatar
So the engine was running, but was knocking... Were the ball bearings still in the race? What does the oil filter look like? You may have dodged a bullet.
Grant
elgyqc is offline   Reply With Quote
Old 01-19-2019, 06:06 PM   #15
NewArt's Avatar
Yes, it’s odd that it ran. I only have the word of the guy who sold it. Not a lot of confidence. The bearing was completely destroyed. No race left. You can see the bolt at the wrong end of the tube. The oil filter had minimal debris in the pleats. I’m hoping to start the teardown tomorrow if I can get my garage above zero!
Old 01-20-2019, 01:24 AM   #16
But....but.....but the IMS is rarely an issue per a lot of forum members on here You have quite the mess there good luck with the repair .
Old 01-20-2019, 06:22 AM   #17
Who's askin'?
maytag's Avatar
Well..... fwiw..... I've been a member here since March last year. In that time, lots of scares and paranoia..... but this is the first real live IMS bearing failure reported.
I'd call that relatively rare. ;-)
Old 01-20-2019, 08:20 AM   #18
NewArt's Avatar
This is a 3.6 Carrera engine that I picked up cheap. My Porsche mechanic friend tells me that these engines are more susceptible to imsb failures than the 3.2s. I can’t verify the veracity of this but I’m looking forward to seeing what sort of collateral damage ensued!
Old 01-20-2019, 08:30 AM   #19
Swing by a reputable shop like Jake Raby's or JFP on this forum and look at all the cars and engines waiting for IMS related rebuilds . Every time I swing by Jake's I just shake my head at the amount of dead Porsche's he has there waiting for repair and almost all are IMS related failures .
Old 01-20-2019, 08:35 AM   #20
elgyqc's Avatar
Which IMSB update is on your broken 3.2? Can you transfer it to the 3.6?
Grant
