Old 11-30-2018, 08:50 AM   #1
gabedrummin's Avatar
Resonance Flap
Dose it matter which way this is installed I noticed after my engine got replaced that it is backwards .The valve should be in between the the intake pipes . This is the valve that is in the tube behind the throttle body tube. The diaphragm for the vale is against the access cover behind the seats and should of been in between the tubes that connect the intake runners.
gabedrummin is offline   Reply With Quote
