Old 11-17-2018, 06:55 AM   #1
Convertible Top Drive Mechanism
Rebuilt the two side drive mechanisms. Made sure each was in the proper alignment. Tested lowering the top and then raising and locking it. Everything ran perfectly. Then on my second test I could not get the Top to go down. Fuse was ok. Appears the switch that engages the drive motor is not working. Is this the toggle switch or is there another switch? The convertible symbol does not
Even appear on the instrument panel. I will try replacing the toggle switch.
JFlowers is offline   Reply With Quote
