Old 11-16-2018, 10:26 AM   #1
problems with drop link replace
had no problem removing nuts from drop link top and bottom. bottom of link out fine but the top bolt would not slide out. used a drift to try and push it out but still no go. Is the strut binding up on the bolt to keep it from coming out? If so how do I remove without removing strut?
ddodgen is offline   Reply With Quote
Old 11-16-2018, 10:50 AM   #2
some of these definitely need a good whack to remove. Maybe try supporting the bottom of the hub with a jack just to remove any possible binding.
Old 11-16-2018, 09:27 PM   #3
Usually a BFH is a bit Neanderthal, but perhaps in this case, just might be the ticket?
