Old 09-12-2006, 01:04 PM   #1
Unhappy Small Problem
Just found out that my car does not have the wheel lock key to get my tires off. So my question is, do I need to go to the dealership and try to get another one or should I just get the old one's cut off and replace. Right now if I get a flat I'm basically SOL.
Thanks!
MAC986 is offline   Reply With Quote
Old 09-12-2006, 01:13 PM   #2
I had the same issue. The dealer has a universal set of multiple keys. I had them take the locking lug nut off then went and had new tires put on. They can also give you the code of the key that fits you're lug nut. I then called the locking lug nut company McGard and told them my delimma. They sent me a new one for about 15 dollars. Here is there web page info
McGard LLC www.mcgard.com
3875 California Road, Orchard Park, NY 14127-4198
Phone: 716-662-8980 • Fax: 716-662-8985
Just tell them its a porsche and the 2 or 3 letter code.
arp35 is offline   Reply With Quote
Old 09-12-2006, 03:01 PM   #3
A cheaper way to remove them would be to hammer (OUCH!!!) a socket onto the lock nut, then use a breaker to take it off. It is a rather drastic method but it does work. You don't have to beat it mercilessly-just find a socket 1 size too small and lightly hammer it until it is on there good and tight. I have done it on 2 occasions many years ago and had no problems later on. I used Craftsman sockets since they are guaranteed for life.
I just purchsed a set of wrenches to remove stripped and rusted nuts. I can't believe how good they work! Don't know if they have these in a socket form but it might be worth a look see. I can't imagine how you could cut them off and not damage the wheel.
Good luck!!
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
Old 09-13-2006, 08:49 AM   #4
Ronzi's Avatar
I thought I had the same problem when I bought my car.
Turned out the socket was hidden in spare tire cover pocket. Have you checked there?
Ronzi is offline   Reply With Quote
Old 09-13-2006, 08:50 AM   #5
Perfectlap's Avatar
^That's exactly where mine was too
BORN: March 2000 - FINLAND
Old 09-13-2006, 10:08 AM   #6
Ditto. I would first check your "tool kit" (which I use loosely). Then I'd remove the tire cover and check inside the tire pocket and around the tire. Since it doesn't have a spot in the kit, it can easily fall out.
'06 Cayenne Turbo S, Beige Metallic/Tan
Ex - '99 Arctic Silver, Red Interior, Silver Top
denverpete is offline   Reply With Quote
Old 09-13-2006, 12:06 PM   #7
Thanks for the all the advice, I did check where the spare tire is and took out the tool kit but didn't find anything. I'll take the spare tire cover off and check again.
Many thanks,
Mac
