11-10-2018, 06:06 AM
#41
Originally Posted by JBauer
Outside pic. OCG I think you are on to something if I can cut it without ruining it
That outside pic looks pretty good. Taking the flat black to the outer edges of the real vent openings puts it in ‘viable’ territory. Everything is in the same visual plane now.
I just checked an eBay listing for these vents. It seems they are fiberglass. I work mostly with hot molded plastics and catalyst urethanes so I can’t be of much help regarding making the cutouts. You’ll need a precision tool to make the tight rear V cuts for sure. Variable speed dremel with a good cutting wheel? Not much material there for the lower vane. Maybe leave a mm or so of material on each side of the vane mold??
Good luck if you decide to give it a go!
Rgds, Fred
11-10-2018, 06:10 AM
#42
I've got a router but I can be scary cutting Fglass. I checked eBay and these things are expensive 😲
I got a deal for sure. Hate ti ruin them
11-10-2018, 06:17 AM
#43
I've got a router but I can be scary cutting Fglass. I checked eBay and these things are expensive ��
Going for that last 2% can be hella costly. Maybe put some black mesh behind the actual vents and call it good? I’ll almost guarantee you’ll ruin at least the first one trying to go for the lower vent mod or it won’t look as good in reality as it does in the imagination
Rgds, Fred
11-10-2018, 06:52 AM
#44
Outside pic. OCG I think you are on to something if I can cut it without ruining it.
This doesn't hurt my eyes as much as the earlier attempt.
11-10-2018, 07:29 AM
#45
2003 S, Arctic Silver, M6
I think this guy is on the right track
11-10-2018, 07:37 AM
#46
I personally prefer the Land Rover/Range Rover style upper back front fender treatment (not). Some of the Explorer guys use even use real RR/LR vents and make them ‘functional’. Whatever floats your boat
Rgds, Fred
11-10-2018, 08:26 AM
#47
Now now now 🙄
11-10-2018, 08:31 AM
#48
OK I found the answer but I'm having trouble finding this stuff. I'm not sure if comes in satin black though. 😐
11-10-2018, 08:33 AM
#49
perfect!
Rgds, Fred
11-10-2018, 08:42 AM
#50
From the Explo forum ‘after saws-all operation on the fender’:
Not sure what it’s venting because I’m certain it doesn’t connect with the engine compartment. I’ve seen worse from a cosmetic standpoint..
Rgds, Fred
11-10-2018, 10:15 AM
#51
Progress :dance:
11-10-2018, 11:04 AM
#52
Yeah, just exposed the fender to a new area prone to rusting... good.
11-10-2018, 02:30 PM
#53
Well I'm done. Looked into cutting out the bottom 2 indents but they have metal mesh inside the fiberglass. I think I'm gonna leave them on awhile and see how I feel about them.
I think I need some side skirts. Any recommendations, pics?
11-10-2018, 03:12 PM
#54
Well I'm done. I think I'm gonna leave them on awhile and see how I feel about them. I think
Maybe like this set?
Originally Posted by wooshhh
can anyone tell me where to find this?
11-11-2018, 05:19 AM
#55
the black looks good!!
99 Porsche Boxster
11-11-2018, 05:31 AM
#56
1998 Boxster Silver/Red
Those skirts are fugly. FUGLY. They look like they weigh 800 pounds.
And that thing on the bumper cover... looks like someone thought, "What other kind of **************** can I glue on my car". No. Stay away from that look. Even rear diffusers would look better than that $.99 Store look
Have a nice day
1998 Porsche Boxster
11-11-2018, 05:58 AM
#57
I think you made a good choice to leave the vents as-is (as-are?). If you decide to keep them, I’d still add the grill material behind the real vent openings. You can see the effect in the pic of my TechArts below.
My Porsche winter project this year is to add side skirts. This will be my second and final external update to my SE (the first being the urethane FVD “turbo look” side vents backed with CCG hexagon grill material). At first I really wanted the Caractere skirts, but I only found one pair in Poland and I decided the look would not integrate well with the otherwise stock bodywork anyway.
I ended up buying three pair to try. CSR, TechArt and Porsche Aerokit 1. I decided to go with the Porsche Aerokit 1 skirts. They are urethane, fit perfectly and they have an understated look that integrates well with the car (imho).
The least expensive I found them new is ~$1,200 for the set so I ended up buying a used set from porscheparts dot com. There’s a big problem regarding the top mounting flange with any used Aerokit 1s which I’ll cover in a separate build thread when I’m done with the install. Here’re pics of my test fittings of the three.
Rgds, Fred
11-11-2018, 07:54 AM
#58
They all look good. Which is in the middle pic?
11-11-2018, 08:07 AM
#59
First pic is Aerokit 1, middle pic is TechArt, third is CSR. Both the TAs and CSRs are fiberglass. The CSRs are Hofele Speed GT replicas. You might also want to consider Porsche Aerokit II skirts (sorry, I don’t have a pic at hand).
Rgds, Fred
11-11-2018, 08:34 AM
#60
Side Vent update
Here’s a pic of the Caractere skirts with your side vents. They kind of compliment each other. Good luck locating a set of the Caractere skirts however.
 o
Rgds, Fred
