Old 10-21-2018, 12:36 PM   #1
Whisp of smoke from vent behind passenger door
I have a faint wisp of smoke that occasionally comes out of the vent behind the passengers door. What is that vent and what might cause the light wisp of smoke that I occasionally see? I can barely smell a trace of something, maybe oil dripping on the hot engine?
Doug427 is offline   Reply With Quote
Old 10-21-2018, 02:58 PM   #2
Oldcarguy's Avatar
That is the intake (not exhaust as many mistakenly believe) for the engine compartment cooling fan. You probably have an oil leak hitting a hot engine part causing the smoke and smell. If so, you need to address this ASAP.
Rgds, Fred
Old 10-21-2018, 10:23 PM   #3
Maybe coolant leak? The over flow is in that area as well. Either way, time to pull some panels and investigate.
