Old 10-22-2018, 02:45 PM   #21
edc
550 Anniversary
edc's Avatar
I'm not quite seeing the relationship between the quality or performance of the bar and an alignment?
Old 10-22-2018, 03:39 PM   #22
Originally Posted by Newsguy View Post
Capitalism is a great concept, but all these parts can be obtained from Rod End Supply for about half that.
You can also go buy an aluminum bar from anywhere, mill the ends, source the attaching hardware for about 1/3 the price, but then again you will have to have the tools/mills to do the machining required, and the time, and the skills...
Like I said, I have been doing stuff like this since I could crawl, I had a hammer in my hands at age 2 and have been turning wrenches for over 50 years now so If I am offering a product, I know it's going to be a superior product that will never fail. But if you want to build your own using parts from Rod End Supply, go ahead. But I have already sourced the items, done the homework and verified fitment.
mgfranz is offline   Reply With Quote
Old 10-22-2018, 03:43 PM   #23
911monty's Avatar
Are the rod end threads reversed so you can adjust the length while on car by rotating the tube?
Old 10-22-2018, 03:44 PM   #24
A stock alignment keeps everything in a correct relationship for proper street performance. I mentioned a trip to the alignment shop to see what changes with the adjustability of this product. From what I can at this time only imagine is that we would be able to dial in/out some camber or toe for track use. Once I get on the rack I will be able to verify.
Old 10-22-2018, 03:46 PM   #25
Yes. And due to a previous request I have contacted the manufacture to see if "flats" can be placed on the tube for a wrenched adjustment. But the tube rotates easily by hand with wheels off the ground.
Old 10-22-2018, 03:48 PM   #26
Originally Posted by Robert986 View Post
Is this "confirmed"? Do we know that it flexes and do we know that there is a real gain by using the stress bar? Comparing with a front strut brace which I believe is considered redundant..
EDIT: Not trying to sound negative, I want to believe... ;-)
Which front brace are you referring to?
Old 10-23-2018, 01:35 AM   #27
MG do you think the aluminum plate will have to have the mounting holes slotted or " opened up " to allow suspension adjustment ? Or do you think there is enough " slop " in the holes from the factory ? You will know more once you get alignment rack results just curious on your thoughts and what you have seen on your own car .
rfuerst911sc is offline   Reply With Quote
Old 10-23-2018, 04:24 AM   #28
I just used some aluminum rod stock and drilled holes. Preloadimg this stuff is pointless in my opinion
Old 10-23-2018, 06:00 AM   #29
I would think that they would need to be elongated some, but let me get on the rack to verify.
Old 10-23-2018, 09:28 AM   #30
Track rat
Topless's Avatar
I can offer my own experience with a strut brace mounted on my 986 for 6 years and 80 track days. I did notice a very subtle improvement in chassis stiffness with fewer creaks going over a swale or up my steep curved driveway. It was subjectively a small improvement, not a big improvement but it didn't cost much so...
Did it measurably improve my lap times? No.
Re: a comparison with a front strut brace? A 986 has a very stiff front chassis similar to a 996 GT3 Cup. No front brace is needed there.
Does it work better on an "S" model than a 2.5L? Lateral G forces are the same on both cars in a corner so there would be no difference. Lateral Gs are mostly a result of tire choice and your suspension's ability to control your contact patch.
Old 10-23-2018, 07:02 PM   #31
I expect this to be more of a "feel" than actually improving lap times, the way I look at it I would expect a firmer plant and an improved stiffness over stock. Time will tell.
Old 10-24-2018, 07:06 AM   #32
edc
550 Anniversary
edc's Avatar
You get this with the plain bar. Don't get me wrong I like the thought and spec in the product but not sure there is any real benefit in it over and above a plain version.
Old 10-24-2018, 04:17 PM   #33
While this might be true, remember I built this bar for the potential of adjustability at the track, (which could be beneficial on the street as well). I have an appointment at my local spec shop on Friday so I should have numbers soon.
Old 10-25-2018, 04:20 AM   #34
What are you plannimg to adjust on the track? Any attempts to increase negative csmber in this manner would be foolish
Old 10-25-2018, 07:14 AM   #35
I don't know about being "foolish", but we'll see. I would think another degree of negative could be beneficial.
Old 10-25-2018, 07:57 AM   #36
Ok, so the piece that holds your control arms and to which this cross bar attaches is held to the body by two nuts and the front crossbrace.
its a fixed assembly and it bolts flush to the body and sits in locating dowel studs.
You A) want to place this piece, which can crack, under tension.
B) Think that you can push this piece further out enough to create an additional degree of negative camber?
The reality is that this bar's only purpose is to stiffen up the rear of the assembly by joining the aluminum carriers (more so than the aluminum plate) and prevent them from flexing under heavy load.
The rear setup of the 986 can get to about 2.4 degrees of camber even with stock control arms via the eccentric setup. Anyone needing more negative camber than that will likely be running adjustable control arms and/or camber plates.
I applaud anyone trying to make new products for this car, but your claims reflect a serious lack of understanding of how the rear of the car is assembled and the manner in which alignment changes should be made.
Old 10-26-2018, 10:34 PM   #37
So I had a chance to get to the alignment shop today, for two reasons. One I wanted to get my setup to RoW and two to see what adjustability was in this stress bar. What I found was this, my stock setup is good but not perfect, it seems that after 92k miles I may need to get into looking for some worn bushings. But I was able to get the proper camber set for initial lapping.
However, what I did find regarding this bar was that simply turning the bar one turn in or out would adjust the toe angle only, one turn IN would change the angle out .10 degrees and turning the bar OUT would result in a .10 degree change in from stock. So no significant camber adjustments, which is kinda what I expected. However after some "spirited" driving after the alignment, I did notice a stiffer feel to the rear.
Old 10-27-2018, 02:28 PM   #38
Track rat
Topless's Avatar
Your new alignment specs look good and will maximize your car for stock suspension running dual purpose street/track use, with much better tire wear. It should turn in better and feel more planted in a high speed 3rd gear sweeper. Now to add some tires with more dry grip that hold up well to continuous lapping.
I agree that the lower stress bar is the wrong tool to add negative camber to the rear. The front is where added camber pays the greatest benefits anyways. Fix that first, then evaluate the rear.
Old 10-27-2018, 02:39 PM   #39
Your new alignment specs look good and will maximize your car for stock suspension running dual purpose street/rack use, with much better tire wear. It shout turn in better and feel more planted in a high speed 3rd gear sweeper. Now to add some tires with more dry grip that hold up well to continuous lapping.
The rear stress bar will have to be fully evaluated at the track, but the development of it was mainly to tighten up the rear and solve a potential weak point in that aluminum pan.
Tires may have to wait, just put on a new set of Falkon Ziex 950 to try.
Old 11-01-2018, 05:27 PM   #40
Track rat
Topless's Avatar
Well, those tires will be fine as an all around commuter A/S tire. On a race track they will overheat and get greasy quick. You will not generate the lateral Gs necessary to thoroughly test your lower stress bar design on those tires.
If you plan to do track days, find a set of takeoff wheels and mount some Extreme performance street tires that add monstrous dry grip and can really take the heat of continuous lapping. They will also make your track day experience more enjoyable.
