10-20-2018, 11:39 AM
#1
Crib
What is this tube?
Hi all,
After having gone through the tedious task of removing my alternator I found this cracked tube behind it.
It is placed directly behind the alternator. The picture is taken from inside the car with the inspection hatch removed.
The inside of the tube has some light oil remains.
Is it something for the AOS?
Thanks in advance guys
/Crib
10-20-2018, 12:22 PM
#2
ves, vents the head on opposite side of the engine over to the aos. part # 996.107.147.55
10-20-2018, 12:39 PM
#3
Crib
Aha. thanks.
Is this the same as the vacuum air filler tube? Meaning it cannot/should not be fixed with heat resistant tape, but rather fully replaced?
/Crib
10-20-2018, 01:32 PM
#4
Man I don't ever doubt what TRK says but in this case, well that is over bank 1 and looks to just be wire loom cover to me. is there a split on it lengthwise and wires in it? The part TRK is referring to goes to the PCV on bank 2.
10-20-2018, 06:35 PM
#5
Artist, 986S tinkerer
No, TRK is right. Should be replaced.
10-21-2018, 04:53 AM
#6
1998 Boxster Silver/Red
Part # 996.107.147.55 looks zero like that illustrated in the picture. TRK always is spot on, but this isn't meeting the acid test. Are you suggesting that the part in the OP illustration was wrapped with wire loom, because it looks like there's a fairly lengthy run of loom. If you run the part number, it appears at the bend there is maybe 4 inches of the loom-look. The OP illustration looks zero like that.
Someone else have an idea/recommmendation? Maybe OP can share what lurks beneath the loom. Wire? Hard plastic pipe?
1998 Porsche Boxster
10-21-2018, 09:10 AM
#7
This is not a "tube" it is simply a wire harness with cracked covering. leave it alone.
Joe K. Peachtree City GA
2001 986 Boxster S, Silver with black interior.
10-21-2018, 12:34 PM
#8
Crib
Hm..
It's certainly not a wire loom. Even though the surface resembles one of those, this one does not contain any wires and the inside of the tube is oily.
My own bet based on previous posts is, that it is the ventilation for the AOS.
I'm wondering if a previous owner took some other kind of piping to replace it. If so I need to investigate the connecting ends of it.
Anyhow, that's life. Almost done with a job, and a new one appears
10-21-2018, 01:07 PM
#9
That is where the AOS breather hose passes behind the alternator, but mine is solid in that section (not ridged).
Where it passes through that section is about where the number "4" is on this diagram. Trace it back to its source to be sure.
10-21-2018, 02:10 PM
#10
I am not guessing here. If you watch my YouTube video https://youtu.be/7OLakpX6Yj8 at around 7:30 you will see this part which I had to replace.
10-21-2018, 02:25 PM
#11
1997 Tip, 2018 Macan
No wires inside = vacuum. The other way to tell wire loom versus vacuum lines is loom is "usually" split completely along it's length.
10-21-2018, 03:16 PM
#12
That's definitely the AOS hose, then. I guess they switched to a fully ridged "flexible" type line at some point. Mine is definitely smooth through most of it.
